Power Steering Hoses
Old 05 Apr 2006, 09:07 pm
Default Power Steering Hoses
Last oil change my mechanic said both my hoses were slightly leaking and needed to be replaced soon! I have searched in here and on google and have NOT found any TSB's or callbacks. I did find one post on the weak clamps on some 2003 turbos. Is there an upgrade for my two PS hoses so I will get more than 50,000 miles on the next set?? [8)]
Old 05 Apr 2006, 09:56 pm
Hopefully someone will come up with your TSB, but the only thing I've heard about power steering hoses is the re-call for the techs to check to see if they are rubbing on the bottom of the transaxle. Appearently, some of the hoses have rubbed enough to cause them to leak and then start a fire.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 05 Apr 2006, 10:08 pm
is your 03 still covered ??
Old 05 Apr 2006, 11:27 pm
No the 7/70 does not cover PS hoses according to my Dealer. But I still want to make the best possible repair. Has anyone heard about the clamps making the hoses leak or if the turbos hoses need to be rerouted or shielded like the normally aspirtated engines needed!
Old 05 May 2006, 04:09 am
I decided since the leak was so small to let it go and see what happens. Cleaned off the hoses and clamps and filled the PS fluid to where it should be. It was down maybe 1/4 of a pint in three years. The hoses were covered with a thin film of something! No other signs of trouble!
Old 05 May 2006, 05:28 pm
Last Fall I had a PS hose come loose, causing a sudden loss of power steering. (OK, I was making a sharp turn at high revs, why do you ask?) After getting to the nearest garage using Armstrong steering, the mechanic who looked at it said the hose fitting had just unscrewed, and he had never seen such a thing before. He tightened it up, refilled the fluid, and no troubles since.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 17 Feb 2009, 07:21 pm
Question Re: Power Steering Hoses
I know this post has been dormant for a while, but I have now experienced a problem with my power steering hose assembly. Just like SteelBlueGT, my hoses started seeping at the pressed fittings. At first I thought it was an oil leak, but not so. One hose was completely soaked on the outside and the rubber has started to deteriorate. I have an extended warranty, so I only had to pay the $100 deductible. The part alone was over $83. Chrysler allowed 1.2 hours, but my tech needed more time. On my 03 Turbo, he had to remove the front grill and raise the fan assembly to access the power steering pump. Everything is now good! :-) My "baby" is an early 03 model built in October 2002 with 24K. I would suspect that this failure is both a time and miles event. Have any of you experienced similar problems? Just curious?
Musicman
Old 17 Feb 2009, 08:59 pm
Default Re: Power Steering Hoses
Had the power steering hoses replaced on my wife's na '04 at an independent shop for $100. Dealer wanted $200.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 21 Feb 2009, 11:54 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
i paid just over a 100.00 for both the pressure and return lines. your dealer is a real schister.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 27 Aug 2009, 06:08 am
Heres a diy on how to change power steering hose,,ive done this many times on different autos and it works perfectly..
Power steering whine problem identified sawdust123 General Turbo Discussions 5 10 Dec 2008 07:24 pm
Tranny Failed then Power Steering Switch? Sami_Girl_FL General PT Cruiser Discussions 22 19 Dec 2007 09:06 am
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
