Back with a new problem. Grrr...
Old 07 Apr 2006, 10:52 pm
Send a message via AIM to Blue Streak
Default Back with a new problem. Grrr...
My PT is really starting to annoy me. First the PCM glitch that caused the engine to overheat, then the ridiculously overpriced front rotor replacement, then the weird misfire issue that took 3 trips to the dealer to diagnose, and now this... This morning in stop-an-go traffic, my ABS momentarily kicked on for no apparent reason and then the ABS and TRAC OFF lights lit up on my dash and have stayed on since. Once I got to a safe location I tested both the ABS and the Traction Control and neither is functioning. The brakes still work fine, I just don't have ABS/TC anymore. I checked the fuse under the dash, hoping that it was something as simple as a blown fuse, but it was fine. Any thoughts as to what might be the problem? [xx(]
Old 08 Apr 2006, 12:34 am
Don't know, but your not the only one.....
http://www.ptcruiserlinks.com/forum/...TOPIC_ID=14564
Old 08 Apr 2006, 10:08 am
hey jeremy, not sure why mine did it [:I] i was driving home from work heard the chimes looked down and the same to lights as you were lit on the dash board , it was damp out some maybe a rotor was alittle stuck ?? i dont know, i started the car up the following morning and all was fine ?? and if i bring it to the dearlership they will say that cant find the problem ?? good luck let me know what happens
Old 10 Apr 2006, 09:55 pm
Well... same senario for me. We finally got some clear weather and everything is back to normal. I hope this isn't going to be a problem everytime it rains. That would sort of defeat the whole purpose of having traction control/abs if it doesn't work when the roads are slick. lol
Jeremy
Old 27 Apr 2006, 12:06 pm
I had the same problem a couple of months ago and it turned out to be a problem with a speed sensor by the front passenger tire.
Dealer replaced it under warranty and that fixed the problem.
Old 29 Jun 2006, 01:04 am
I'd agree with this. I've seen more than one WSS fail at very low MPH.
Old 29 Jun 2006, 05:41 pm
anymore trouble with the car ??
Old 06 Jul 2006, 09:58 pm
Blue streak,
i too have the weird misfire thing, especially at idle, what did your dealer diagnose it as, cause ive been there twice and theyve done nothing to fix it so far. If its the same hopefully if i tell them what yours was doing they could finally fix mine....
Mike
Running out of patience with CEL problem coolvirus General Turbo Discussions 5 19 Mar 2007 10:42 am
better put your back seats back Ctown General PT Cruiser Discussions 0 26 Feb 2006 11:21 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Back power window switches not working lumofny Tech & Performance Forum 3 16 Jan 2005 10:00 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
