Multiple Codes (P0340/P0522)
Old 10 Apr 2006, 06:36 pm
Default Multiple Codes (P0340/P0522)
My '03 is almost 50K old and I am having two codes pop up and a few related problems. First code, P0340, is camshaft position sensor circuiit, and the second is P0522, engine oil pressure sensor/switch circuit-low voltage. Now what my car does. All of a sudden while driving my emission control light will come on. Then, while driving (manual tran) at about 3000RPM in every gear the engine cuts out abruptly. My cure for this is put the car in neutral and turn it off and then back on (while moving!). The engine cutout stops then, but the emission light remains on for a few hours or days, depending. Also, sometimes when the light is on the car will not start for a few minutes and then just comje back to life like nothing is wrong. I have had problems with plugs and wires before. I changed my plugs twice and replaced my wires once. Maybe its time for some better wires since I replaced my original ones with oems. Any info or feedback is appreciated.
Old 10 Apr 2006, 07:49 pm
hello - i had a chrysler lhs with this same sensor problem/code. replace the sensor. it's one small bolt and a connector. i got my sensor at my local parts store (kragen) for less that $50. after you replace it, either reset your check engine light with your scan tool or disconnect the battery for 20 minutes. let me know if you need help locating the cam shaft sensor. i have a pt dealer service manual and will look it up for you.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 10 Apr 2006, 09:10 pm
Send a message via AIM to Bosch
Yep I just replaced mine, the oil pressure sensor.. $16 dollar part at the high priced stealership..
The camshaft position sensor is another common but less common problem with the PT.. On the 01's it was real common for those to go bad..
Driving a 2001 27F Patriot Blue! Blue Flamed Floor Mats. Blue Flamed Seat Covers. Flameball blue \"Hair\" shiftknob. Blue behind the grll neons. FlowMaster Exhaust. Freedom Design Strut Tower Brace. Painted Smoothies. Road Runner horn! Meep Meep!
Old 10 Apr 2006, 10:28 pm
About a year ago I got the CHECK ENGINE light and my PT came to a halt while doing 80MPH at 11pm on I-95 in South Carolina heading back home to Florida. Code read P0340 and I was in the middle of nowhere. Called for a tow truck, spent overnight in a hotel and towed to a dealer in the morning. Dealer wanted to replace the Cam sensor and wanting to get home I said OK. Mechanic was taking things apart up on the lift when he saw the the wiring harness that had the wires from the cam sensor had come loose from the mounting and wiggled their way down to the half shaft on the passenger side. Hitting the spinning shaft, the insulation and then the wires burnt thru causing the cam sensor signals to be interrupted. No signal, no spark! He soldered the wires back together, shrunk wrapped the harness and tied everything back up out of the way. Cost me half a day and two hours labor. Oh yea, the tow truck broke my front undercar light and the dealer lift broke another light on the side.
The cam sensor wires run along the back of the engine just above the oil filter, so check to see if all the wiring up there is tied out of harms way.
Old 12 Apr 2006, 12:25 pm
The others covered the sensors - as to wires, I've read of nothing but good and my own experience on both PTs is that Crane wires are the way to go.
www.RaceAndStreet.Com will get them to you in a few days.[?]
Old 05 Dec 2008, 12:38 pm
Default Re: Multiple Codes (P0340/P0522)
HI I am Ken Letizia, my girlfriend has an 06, and lately the P0340 has been popping on and off. She is driving and the car starts to stutter and then sometimes takes a few tries to start. Can you help me locate the camshaft position sensor and fix this problem?
Any help would be appreciated.
Ken.
Old 05 Dec 2008, 08:22 pm
Right side of the engine towards the front.
Old 03 Feb 2009, 01:43 pm
Send a message via MSN to grandpaof5
my '05 shows the code P0344.... is this something that I can replace or should I keep my appointment for the garage??
Old 03 Feb 2009, 02:39 pm
Same answer as above. Sensor should be somewhere around $45. Yes, it's an easy fix.
Old 04 Feb 2009, 11:56 am
Cam sensor is a 30 minute fix at most. Pull the air box and the IC to throttle body pipe. I also had to remove a coolant feed pipe that blocked one of the bolts but some don't from what I hear. Pull the old one (2 bolts), put the new one on and put it back together. easy squeezy.
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
2003 Error codes Reed Tech & Performance Forum 4 15 Aug 2007 08:12 am
Check Problem Codes Yourself! turbomangt General PT Cruiser Discussions 13 23 Feb 2006 06:27 am
