Engine Decarbonization??
  #21 (permalink)
Old 13 Dec 2008, 01:52 am
Default Re: Engine Decarbonization??
I think motor mounts would be near $1000 if you have no warranty. I know for sure that a water pump installation is $851 at the dealer with no warranty. If you get both done at the same time, the motor mount labor will be less, and you can throw in a new timing belt while they are doing if for lot less. My water pump failed at 35,000 miles and the timing belt had cracks in it probably from the 110 degree heat that my PT Cruiser is driven in. The motor mounts had cracks in them too at the same mileage and had to be replaced. It is best to have a Chrysler dealer do this work because other garages can exceed the book time if they have no experience with this car.
  #22 (permalink)
Old 13 Dec 2008, 09:32 am
tinosa's Avatar
I've used Mopar Combustion Chamber Cleaner Part # 04318001 in a Ram and a Cherokee in the past. It's an aerosol that cost about $10 or $15 at the dealer. Just follow the directions on the can.
Since the only gas I can buy is %10 ethanol, I wonder if is necessary for my PT?
  #23 (permalink)
Old 17 Dec 2008, 05:37 pm
I've used the TECHRON additive for a long time, it's worth the cost, my cars run smoother & get better mileage.
BTW, anyone ever added MARVEL MYSTERY OIL to their gas tank? The instructions say it has lubricating qualities ... sounds like a good thing.
Silver 2001 Limited,
-doc
  #24 (permalink)
Old 17 Dec 2008, 06:30 pm
crusierdad76's Avatar
seems a lot of things seem really expensive on the PT the timing belt is over $1000
  #25 (permalink)
Old 25 Mar 2009, 03:32 pm
The best and cheapest decarbonization is water. Run it through a manifold vaccum line or pour slowly down the throttle body while at about 2,000 rpms. Just don't let it stall or it will screw up the engine.
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine problem BORICUA Tech & Performance Forum 49 03 Apr 2006 05:15 am
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
TSB 1802903: Engine Misfire PTskilla General Turbo Discussions 0 18 Aug 2003 12:13 am
