TURBO LITE VS GT TURBO
Old 24 May 2006, 01:58 pm
mjb457's Avatar
Default TURBO LITE VS GT TURBO
[:I]Are the engines beefed up in the Turbo-lite... like the GT Turbo.... forged rods,pistons etc??/ Any idea ??[8)]
Old 24 May 2006, 02:47 pm
as has been stated numerous times, the only difference between the turbo and the turbo lite engines is PCM programming. Same internals, same turbos, same intercoolers, etc. Same auto tranny, just that the GT gets an AutoStick shifter and different programming in the TCM to make it work. The Turbo lite PCM is detuned to allow it to run on 87 pump gas. Hence the lower power numbers. Add Stage 1 to either, though, and you end up with the same power levels, and the same need to use premium fuel.
Old 24 May 2006, 03:18 pm
quote:Originally posted by banned_but_not_forgotten
Same auto tranny,
I read that in '05, I think, they dropped 2 clutch packs from the auto for non-turbo PTs. Up 'till then, all PT autos were the same.
41TE - turbos, 40TE - non-turbos.
And yes, engines are the same.
Old 24 May 2006, 04:20 pm
Same auto tranny,
You are correct, but he didn't ask about the N/A, just the HO and Turbo-lite. Those ARE the same.
Old 24 May 2006, 06:18 pm
mjb457's Avatar
Clutch packs??? please explain,, even though Im sure its been done before again thankyou... im trying to decide on trading on up to an '06 turbo-lite PT Limited... mine is very cool chromed '03 but NA & I have a decision to make [:I]
Old 24 May 2006, 07:56 pm
[8)]Cough up the extra bucks for the High Output you won't be sorry.
http://memimage.cardomain.net/member_images/10/web/2098000-2098999/2098527_7_full.jpg
Old 24 May 2006, 10:18 pm
No, you get the Turbo Lite and drop in a Stage 1.
Save a few bucks, and get a *real* kick in the pants.
[8)]
Old 25 May 2006, 09:21 am
the 41TE auto transmission has 4 clutch packs, and come in turbo PTs - both turbos. Non-turbo PTs get the 40TE auto with only 2 clutch packs. Obviously, it was done to save money - I guess the torque rating of non-turbo is okay with fewer cluch packs.
Old 25 May 2006, 04:14 pm
mjb457's Avatar
[:I] Is that the same for all years?? Clutch pack issue? [8)]
Old 25 May 2006, 04:41 pm
no, please read the thread.....
in 2005 Chrysler switched to a 40TE auto in NON-TURBO's
40TE = 2 clutch packs.
Prior to 2005, ALL PT's had a 41TE auto
41TE = 4 clutch packs
Therefore, all TURBO PT's (including Turbo Lites) have the 41TE
Without explaining to you how a 4xTE transmission operates, the difference is that with 2 clutch packs, you can hold less torque, hence their use in normally aspirated (low HP and torque) PT's. It's a cost saving measure.
The Turbo's still have the 41TE, which will hold more torque (although not much more than stock)
TURBO LITE VS GT 1MEAN PT Stage Turbo Kits 12 02 Jul 2004 09:37 am
GT vs Turbo lite parts? Jimbo General Turbo Discussions 10 11 Apr 2004 11:03 pm
Turbo Lite w/5-spd? TomCatMi General Turbo Discussions 2 21 Mar 2004 10:21 pm
Auto Stick and The 180 HP Turbo "Lite" FRM3 General Turbo Discussions 5 26 Oct 2003 04:00 pm
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
