Gauge Pillar Pods
Old 23 May 2003, 12:30 am
Send a message via AIM to ptcruzin42
Default Gauge Pillar Pods
What gauge pillar do you all recomend? Also will the color match on the one you suggest or will I need to paint it?
Old 23 May 2003, 01:28 am
I don't think anyone makes one that matches the GT ! So you'll end up painting it !
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 25 Apr 2009, 05:05 pm
wantaptcruiser's Avatar
Default Re: Gauge Pillar Pods
Chrysler PT Cruiser Gauge Pods
I was looking at these a-pillar pods and really like the looks of them. I'd be getting a gray one, but am wondering if anyone knows whether or not they are full replacements or not? I know some companies make them but they're just a tad bit shorter than the original piece.
Old 30 Apr 2009, 02:36 pm
i purchased all my gauges and pillar post from glowshift.com. there is no actual snap in replacement. it is more of a cover with three pods. you will have to drill holes into your oem one for the wires for the gauges. and then you just use the screws that are supplied to secure the cover to your existing pillar. i don't know how to insert images but if you go to my gallery you will see pictures there.
Old 01 May 2009, 12:20 pm
nevinsrt's Avatar
PT Cruiser Pillar Pod Dual or Tripple: Race and Street
buy this pod you can chose what factory color you want it.
this is were i bought our 3 pod.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 01 May 2009, 12:26 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
On word of caution on the tripple pods, if you are short like me you may have issues seeing the upper most gauge. So either put something there you don't need constantly or go with a double pod.
Just something I learned along the way.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
Pillar gauge pod for ragtops? Capt Kidd Interior Accessories Forum 0 01 Aug 2006 07:17 pm
Pillar gauge pod Capt Kidd Interior Accessories Forum 0 08 Jul 2005 07:59 pm
pillar gauge pod Capt Kidd PT Cruiser Convertible Forum 0 08 Jul 2005 07:54 pm
install gauge pillar pod nhrapt Non-PT Discussions 0 30 Jun 2003 05:30 pm
