When my battery gave up the ghost it was really at a bad time for me! First thing that happened was that the battery showed a lot of white corrosion all over and at the terminals. I cleaned it up put in battery terminal savers and then my trip odometer would reset to zero when I shut the engine off. Then it cranked kinda slowly for a few months. Then wifey backed out of the garage and it stalled and the check engine light come on. It would jump start but not keep running. Towed it into the dealer on July 1 and it came back to me on July 3 fully fixed with just a new battery and a new cable connector as the old one was corroded. Total cost $180 about half for new 5 yr MOPAR battery and half for labor. The check engine light was caused by the lack of battery output according to the dealer.
My advise is that after 4 years or if your trip odometer is suddenly resetting get a new battery. Mine did not make it to 4 years (oct 02) but I should have changed out to an Optima and saved a lot of trouble. I love the fact that the trip odometer is workiang again after 9 mo of not working.
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Hey guys...batteries can be the most fickle things on a car. My early '01TE (March '00 build) has the original battery still. Yea, I know and agree any moment.... My '03 turbo still has it's original with no issues (could change tomorrow). You never know. Simple checks (water level, connections, cleaning posts, etc. DO make a difference. Everyone worries about cold weather. Heat is far more damaging than cold, particularly exessive heat like the turbos generate. Cold quickly zaps a weak battery because it takes more energy to crank a cold engine. Just my .02.
PT4U2C/1KICKNPT
01 TE Shale Green 17\" Casinos w/Kuhmo 712\'s Bassani,Stull,Full Xenon detailed engine,K&N blane struts: 03 Dream HOT Lot\'s of chrome, Mopar duals, T&T grille,Air raid Blane struts, autotecnica head/tail light trim, street-rod, turbo badging,auto meter gauges w/pro pod full LED\'s |
![]() I had a used Chevy Blazer that was 3 years old when I got it that still had the factory battery in it. By maintaining it, the battery lasted for the entire time I owned the truck, which was 5 years. So taking care of your battery the same way you take care of your engine and it should last just the same.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold. Mods On The Way: AGP Wastegate Actuator |
The 4 years about battery lifespan must be true, my GT 5 Speed '03 is now at the stearler (a broken radiator issue) and the tech told me that the battery is leaking acid so it's time for a new one, now i know why the trip odometer was reseting to 0 every time. Oh well bye bye $130
Hi, I'm selling a USA GT Turbo for a friend here in the UK. Unfortunately he's very ill in hospital and I can't talk with him. His car has been idle for a while and now needs a new battery, it will not hold any charge at all. It is a 03 GT Turbo, my problem is that I can't identify the battery for replacement here.
Can anyone give me a model number or brand name, anything that can help me find a battery here in England. There is a Costco near to where I live, but they can't identify the battery, but say they might be able to get one. UK battery sellers just say 'can't help you' or 'I need more info' - sigh... Please help! |
Interstate Batteries - Every Battery for Every Need
2003, GT, "ShuggaPlum", xenon bumper kit and Accra-Form Running Boards, custom tan/black neoprene seat covers (front & back). Houston, TX ![]() ![]() ![]()
That's a great help, many thanks.
At least I now have the amperage ratings and a new number to try. You're a star. |
Our 2003 PT GT's battery is on it's last legs. I'll be replacing it at end of Summer 'cause it won't make it through another Winter.
| PT Crusier battery dies after 5 days of no use. | PT OWNER | General Turbo Discussions | 22 | 28 Jan 2009 11:51 am |
| Optima Battery | Gear_Head | General Turbo Discussions | 11 | 09 Nov 2007 02:47 pm |
| Battery Corrosion | SteelBlueGT | General Turbo Discussions | 9 | 19 May 2005 06:47 pm |
| BATTERY SOURCE NEEDED | clevelandmike | General PT Cruiser Discussions | 3 | 06 Oct 2004 09:54 am |
| Volume reduced when battery disconnected | tom-t-rifik | Sound and Security Forum | 0 | 28 Jun 2004 05:25 pm |
