start problem
Old 11 Sep 2006, 05:24 pm
Default start problem
several times now I have gone out (engine cold or hot) and all electrical items work but engine does not crank...try it several times-nothing, wait 10-20 minutes and try it again then it will start right up. anyone have a similar problem or have any ideas?
Old 12 Sep 2006, 09:59 am
Possibilities:
ignition switch - try taking key completely out and re-inserting
Starter solenoid - may be going
Starter - could have a "bad spot"
Battery - how old is it?
Old 12 Sep 2006, 11:14 am
Starter Safety Interlock? Sometimes these switches get flakey.
-With an automatic tranny run it up and down a couple times then back to park, or try starting it in neutral.
-With a manual pump the clutch a couple of times.
Also: are you getting any codes?
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 12 Sep 2006, 11:00 pm
Well, Quick listed several things that are all good possibilities. I would however add.....
Clutch saftey switch
Transmission range sensor
PCM
Starter relay
Wiring harness
PDC
Connections at battery
Hmmm.....I love a good electrical challenge.
At the very least your going to need a test light and a wiring diagram....or a good tech. Have you got a test light?
Old 13 Sep 2006, 05:47 pm
yes, I have a test lite and am pretty DC savy
Old 20 Sep 2006, 03:01 am
The first thing that I'd do is to check the battery cables, make sure thier clean and tight. Check the the other end of the ground cable where it attatches under on of the bell housing or starter bolts. You going to have to put the test light on the little wire at the starter when it won't crank and see if it lights up when the key is in the crank possition. If it lights up nice and bright then it needs a starter. If it doesn't then we'll take it from there.
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Cold Start Problem Mean Green General Turbo Discussions 2 17 Jul 2004 12:37 pm
I know someone else had this problem..... yobiebs General Turbo Discussions 12 15 Aug 2003 09:48 am
....my god, let's start over with the stage 1.... earringboy Turbo Performance 0 07 Jun 2003 03:35 pm
