IS THE LOUD, SHORT,METAL SOUNDING CLUNK UNDER THE HOOD OF MY GORGEOUS RED `03 GT TURBO CARBON-FOULED SPARK PLUGS?? FAULTY SPARK PLUG WIRES?? TURBO BLADES HITTING THE CASING?? INTAKE MANIFOLD GASKETS?? BAD GAS??[xx(]
Hard to tell where a noise comes from when we can't hear it. When did you last replace the plugs? The OEM plug wires are junk and break down quickly. Your're going to have to chase it down or take it in. Please don't use caps. It's like shouting and hard on the eyes.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
It could be this as well... [:I]
NUMBER: 09-007-04 GROUP: Engine DATE: March 2, 2004 This bulletin is supplied as technical information only and is not an authorization for repair. SUBJECT: Irregular Engine Snapping Sound OVERVIEW: This bulletin involves chamfering the bore radius on cam bearing caps L2 through L5 and R2 through R5. MODELS: 2001 - 2004 (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan 2002 - 2004 (KJ) Liberty 2002 - 2004 (KJ) Cherokee (International Markets) 2003 - 2004 (PL) Neon 2001 - 2004 (PT) PT Cruiser 2001 - 2004 (RG) Chrysler Voyager (International Markets) 2001 - 2004 (RS) Town & Country/ Caravan/Voyager 2003 - 2004 (TJ) Wrangler NOTE: This bulletin applies to vehicles equipped with a 2.0L, 2.4L DOHC or 2.4L Turbo engine (sales code ECC, EDZ, ED1, EDV, ED2 or EDT). SYMPTOM/CONDITION: The sound may be noticed when the engine is idling in park between idle rpm and 1400 rpm at normal operating temperature. The sound is on the upper end of the engine (cylinder head) towards the front of the engine or passenger side (right side). The sound is irregular, not periodic or harmonious. The frequency of the sound will increase with RPM. The sound is more of a higher pitch snapping noise not a low metallic knock. DIAGNOSIS: If the vehicle operator describes the Symptom/Condition and the technician determines that the sound is from the upper end of the engine (cylinder head) towards the front of the engine or passenger side (right side), perform the Repair Procedure. 09-007-04 -2- REPAIR PROCEDURE: 1. Remove the cylinder head cover (Refer to information available in TechCONNECT 9 - ENGINE/CYLINDER HEAD COVER - Removal) 2. Remove L2 cam bearing cap (Fig. 1). NOTE: Do not remove the #L1/R1 or L6 cam bearing caps, or loosen the fasteners. NOTE: Only remove one cam bearing cap at a time. Fig. 1 CAMSHAFT BEARING CAP IDENTIFICATION 3. Lightly chamfer the two bore radius edges with a small hand file, creating a 45 chamfer 1.0 to 1.5 mm in width along the edge of each bore radius (Fig. 2). CAUTION: Be careful not to scratch bore surface of cam bearing cap. Chamfer both bore radius. Fig. 2 CAMSHAFT BEARING CAP 1 - CAM BEARING CAP RADIUS 4. Clean part to remove any aluminum filings prior to reinstalling. -3- 09-007-04 5. Reinstall L2 cam bearing cap by loosely assembling fasteners. Prior to and during the torquing of each fastener, twist the cam bearing cap by hand in a clockwise direction, as viewed from the top of the engine. Torque M6 fasteners to 12 N·m (105 in. lbs.) while maintaining a clockwise twisting force on the cam bearing cap. 6. Repeat steps 2 through 4 for cam bearing caps L3, L4, L5, R2, R3, R4, R5 and R6. |
let us know what you find out !!
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip. |
| Noise in front when making left turn; not right | Runkle | Wheels, Tires, Suspension | 2 | 12 Feb 2007 01:04 pm |
| "Mysterious" turbo engine noise...??? | Gary04GT | Turbo Performance | 76 | 21 Aug 2006 08:28 am |
| after recall repair: new rubbing noise | otrqt | Tech & Performance Forum | 2 | 16 Jan 2005 11:32 pm |
| Road noise / exhaust noise in the car. | jackatg450 | Tech & Performance Forum | 3 | 21 Jul 2004 10:55 pm |
| acceleration and decceleration popping noise | Art Rigby | Tech & Performance Forum | 1 | 06 Oct 2003 02:30 pm |
