PT Cruiser Forum Car Videos
Car Rims
Check Engine Light came on - code 1188?
  #11 (permalink)
Old 24 Nov 2006, 02:56 am
Paw Paw is offline
Location: Upper Sunshine Coast, British Colimbia, Canada.
Ah, the dreaded P1188 code. I lived with that code for over 2 years coming on and off. It is not the turbo, try tracing all your vaccum lines starting from passenger shock tower. After 2yrs and many visits to various dealers and PCM flashes. The problem is caused by a missing vaccum hose to a sensor located on the psgrside firewall. My code is usually trigger when I try to give it a little more accelation from a cruising speed or when I try to throttle up while climbing a hill.
Hope this helps
PAW
  #12 (permalink)
Old 24 Nov 2006, 10:29 am
bobs turbo pt bobs turbo pt is offline
"Chysler "SHOULD" be more involved in the dealerships'"
thats for sure !!
  #13 (permalink)
Old 27 Nov 2006, 10:44 pm
Paw Paw is offline
they do, I think. If the tech or the dealership is willing to contact DC's tech support with question to problem they can't resolve.
  #14 (permalink)
Old 28 Nov 2006, 01:50 pm
thegoldpt's Avatar
thegoldpt thegoldpt is offline
Send a message via MSN to thegoldpt
quote:Originally posted by strangelove
Hey, Thegoldpt can we make that error code list a sticky?
done
2005 Linen Gold 5spd
PT Cruiser Links Moderator
  #15 (permalink)
Old 28 Nov 2006, 05:20 pm
sticky awesome idea !![^]
  #16 (permalink)
Old 30 Nov 2006, 07:41 am
strangelove strangelove is offline
Thanks for the sticky gold, figured someone we could all use a error code list, and an easy place to find it. Every time I had to search for it, I had to go now how did I word that search on google, kind of like searching trough that old drawer that's now crammed full of old papers and junk. I've gotta start organizing my bookmarks.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
  #17 (permalink)
Old 08 Jan 2008, 07:49 pm
JaviPTGT's Avatar
JaviPTGT JaviPTGT is offline
Send a message via Yahoo to JaviPTGT
Cool Re: Check Engine Light came on - code 1188?
hey thanks that code has been on and off for about 3months and i took off my Boost controler and intake as well as the spring mod thinking i messed up my car. I am adding a neno computer for the airfuel ratio, do you think that would help? Do you know where i could find the wiring diagram so i can install the computer.
Thanks
Javi
  #18 (permalink)
Old 08 Jan 2008, 08:09 pm
dklipfel dklipfel is offline
Default Re: Check Engine Light came on - code 1188?
Error codes are all good info - but - what the heck is a sticky?
p.s. Haven't been to a dealer for service (except for recalls) in over 30 years. Figured cost savings have paid for at least one new car!
Dave, 2006 PT GT,Linen Gold, fully loaded
  #19 (permalink)
Old 09 Jan 2008, 01:14 pm
03electricbluegt 03electricbluegt is offline
The p1188 code is usually thrown when you have too much boost in a part throttle condition. Boost is building against the partially open throttle plate causing the pressure in front to be higher than the PCM expects. A manual boost controller will do this as it tries to keep the boost at the setpoint of the controller if the engine is producing enough oomph to maintain it. A spring modification on the wastegate actuator will do the same thing. Any dealer mechanics who know our turbo systems will know that you have been playing with the boost if you take the car in with this code and they find no issues with the factory hardware. It's not impossible to get that code while stock if your wastegate is acting erratic or if a hose is leaking/unplugged but you may tip them off that you have been modding your car and give them grounds for warranty denial in the future. Pull any boost mods off your car and reset the PCM. If the code returns you may have a vacuum line pulled off as someone else suggested, but the code will most likely never show up again, until you put mods back on.
Stage 1 is much more forgiving of higher boost levels. I don't know what your mods are but your mechanic is right on. Too much pressure in the upper charge pipe just before the throttle.
Brian
vB code is On
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
CHECK ENGINE LIGHT MEXICANPT Stage Turbo Kits 3 08 Aug 2003 11:13 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 11 10 Jul 2003 04:55 pm
  Loans | Mortgages | Car Insurance | Loans | Free Advertising
