overheat
Old 18 Nov 2006, 04:43 pm
Default overheat
Hello everyone. On the way home today the coolant gauge went all the way up to the red and gave me the chime warning and then it dropped back down. This is the second time this has happened . Can any of you guys tell me what is going on? Thanks in advance.
Old 18 Nov 2006, 05:06 pm
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
Check for fault codes on the computer.. Your tempature sensor is going out.
Old 19 Nov 2006, 12:06 am
Do you mean put the key in the ignition and turn 3 times? Tried that and no code came up.
Old 19 Nov 2006, 12:01 pm
are you low on anti freeze ?? and are you putting the key in and advancing it to just before it starts and then do that two more times ??
Old 20 Nov 2006, 12:25 am
You might have something clogging the emgine coolant ports. Flush it with radiator cleaner like Prestone radiator flush, run water throught the radiator for fifteen minutes and replace the old coolant, I've used Prestone Dexcool which works just fine.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 20 Nov 2006, 09:40 am
Were you stopped when gauge shot up? Some folks have had the fan die. Once you're moving, temp drops without fan.
Old 20 Nov 2006, 05:56 pm
thegoldpt's Avatar
Yeah thats strange because when mine went out they had to replace the coolant sensor when it did something strange like that.
Old 21 Nov 2006, 02:19 am
I was at a stop light, then when i started to acclereate it shot up then shot back down.
Old 21 Nov 2006, 09:45 am
If it really shot up and dropped quickly, sounds like an air bubble.
When the car is cooled off, take off radiator cap - coolant should be right at the top.
Old 24 Nov 2006, 05:46 pm
did you find the problem ??
