PT Cruiser Forum Car Videos
Custom Wheels
Not sure what this is ... help, please.
Old 02 Dec 2006, 02:13 am
onedivinehammer onedivinehammer is offline
Default Not sure what this is ... help, please.
Here's what happening: While driving there is a loud, in a deep manner, somewhat grinding noise coming from what seems to be not so much the engine but the tranny area.
What I've noticed: The noise does not come about during idling, or while stopped (i.e. revving the engine.) It only occurs during driving times, increasing in sound level with the speed of the car. (Highway driving produces headaches at times.) There is absolutely nothing wrong with transmission in regards to shifting (I have a stick). Tranny does not stick, miss, or anything like that. What seems to be the most interesting item is that the noise goes away (instantaneously) when I turn the wheel left. For instance, while on the highway you have curves or slight turns in the road; while turning left the noise goes away, while turning right the noise increases.
Any ideas? Has anyone experienced this? I do have 80,000 miles and never have had a mechanical issue to date. Is it the steering column, bushings, or bearings?
Old 02 Dec 2006, 10:49 am
bobs turbo pt bobs turbo pt is offline
sounds like it could be a bearing noise [:I]
Old 02 Dec 2006, 01:16 pm
wait4me6920 wait4me6920 is offline
I'd agree - it's probably either a wheel bearing or a cv joint problem. The cv joints usually rattle mostly in turns, though if they're far enough gone they'll rattle a bit on straight road as well.
You might also do a visual to make sure nothing has come partially loose - brake assembly, suspension components, etc.
2005 Turbo Lite, Stage 1, Mopar/Borla cat-back exhaust, Eibach swaybars, Bilstein coilovers, 18/8 TSW Montage wheels with 225/40/18 Exclaim UHPs, LED taillights, K & N drop-in & a few other goodies...
Old 03 Dec 2006, 05:01 am
strangelove strangelove is offline
If not a cv joint could it be abnormal tire wear.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 04 Dec 2006, 08:54 am
Wheel bearing my first guess, CV joint second.
Let us know what it was when you cure it.
Old 04 Dec 2006, 05:47 pm
keep us posted and good luck !!
Old 06 Dec 2006, 10:28 pm
Cal Cruzer Cal Cruzer is offline
CV joint is my first guess. I just had one replaced and I am hearing more and more people having similar noises and problems. They will go a long time after they start to make noise though.
Old 08 Dec 2006, 12:27 am
bmanmg bmanmg is offline
You have a bad left front wheel bearing. When you turn to the left you take weight off the left wheel bearing(unload it)and the noise goes away. When you turn right you load the left wheel bearing and the noise gets louder. That is how you test for a wheel bearing noise.
Bob
Old 26 Dec 2006, 06:50 pm
Bmanmg was right! Thanks, I appreciate the feedback.
\'03 5-spd GT Turbo
Stage 1
AiRaid Intake System
Eibach Pro Kit Springs
Eibach Anti-Sway Kit
BTG Turbo Strut Bar
Ceramic brake pads
Mopar/Borla Dualies 2.5\"
Oh ... it\'s Onyx Green
vB code is On
  Remortgages | Discount digital cameras | Personal Loans | Mortgages | Debt Loans
