i think tranny is bad
Old 04 Jan 2007, 05:22 am
Default i think tranny is bad
first off i would like to say Hi. i am 20 i went to an automotive college so i know the ropes.
problem: while accelerating from 40 to 60 my tranny slips. so i let off of the accerlerator and push it again. after 65 mph 2300 rpm it goes away.
what do u think i should do? get a new tranny? car has 44,000 miles. PTGT 2003. do u think that a tranny service "drain& refill/filter change" will fix it?
Old 04 Jan 2007, 10:13 am
Welcome.
I would find a place that does a flush (not just drain & fill). It changes all the fluid. The routine should be: drop the pan, change filter, put old fluid back, then hook to flush machine. Ran me about $200. If you're out of warranty, Go with ATF + 5 ( I believe Valvoline makes it)- it's later and surpasses ATF + 4, but isn't recognized by Chrysler.
If that doesn't cure it, then it'd be the clutch packs.
Old 04 Jan 2007, 07:39 pm
is the car still covered ?? if not i would do as don says
Old 05 Jan 2007, 03:51 am
no i bought the car used..... it had 41000 miles when i got it. and just about 1000 miles ago i noticed it. i hardly ever abuse my car. i drive 50 miles a day to and from work so it my horse.
and i got powertrain
03 PT GT Patriot Blue, fully loaded except for leather.
Old 05 Jan 2007, 10:15 am
You MAY have 7/70 powertrain warranty. Write down VIN # (visible thru windshield on driver's side) and check with Chrysler or dealer.
If not, price out and ask about clutch pack replacement, whether to replace means fluid has to be drained. If not, start with the fluid flush and see, then you may have to do clutch packs.
Old 06 Jan 2007, 04:45 pm
If it is not covered with the 7/70 warranty then go to a trany shop that knows this tranny well and get it diagnosed properly. I had solendoids go out on my 03 under the 70,000 waranty so it cost me just $100 at 60,000 miles! Two weeks later I did get my 06.
Old 06 Jan 2007, 07:45 pm
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
Sell it, buy a manual.. my 2 cents
Old 07 Jan 2007, 01:41 am
"go to a trany shop that knows this tranny well and get it diagnosed properly" well said !![?]
Old 07 Jan 2007, 01:24 pm
lol i just got out of college.... i got a job 6 months ago at General Motors making 21.60 /hr. but i can be layed off at any time so i am not looking to dig myself in a large hole " this small one is fine thankyou"
Old 08 Jan 2007, 07:29 pm
hi - i think it would be worth a trip to the dealer. it may fall into the powertrain 7/70 warranty. i had my turbo replaced at 25K at a local dealer here. the work receipt stated it was a powertrain 7/70 warranty. it only cost be a $100 deductible. the dealer gets paid either way. i bet they even pad their warranty work a little to screw corporate. my 2 cents.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Tranny cooler? sawdust123 General Turbo Discussions 2 07 Jun 2005 09:14 am
Tranny Shifts Rough SteelBlueGT General Turbo Discussions 2 08 Mar 2005 11:38 pm
Auto Tranny Maintenance SteelBlueGT General Turbo Discussions 3 28 Oct 2004 05:40 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Burned up 2nd and 3rd gears in Autostick tranny. Rainman General Turbo Discussions 6 16 Mar 2004 01:40 pm
