Hi i have a 03 GT with 40K. I have a miss at idle on the #4 cyl. onlywhen it idles and while im driving the turbo is putting out like 8-10 #'s and all of a sudden shoot up to around 20#'s for a second and go back to norm. the car sat for 2 weeks and when i went to work on the miss (check plugs)the #3cyl. plug was wet with gas. Could a leaky inj. on #3 make #4 miss?other than that the plugs were fine.the wires are 8months old (8.5mm)new wires are coming in tomarow morn. Back to the boost surge could that be the BOV? i heard there is a rubber valve that sometimes tears.has anyone heard of this?
i put new wires on and it did the same thing so i switched the firing order (waste spark)to check the coil and i checked the resistance in the primary which was good. i will try the wd-40 when i get out of work tomarrow. I got that plastic intake man. and will be putting that on when i get the stage 1 which should've been here a week ago.
Coils on the PT hardly ever go bad - and when they do, they take out 2 cylinders...
You getting any error codes (P304 only?). If you're going to do the new manifold, look carefully at the gaskets - specially around 3-4. On another PT forum, couple guys had problems similar to yours and that's what they found (Intake gasket bad)[:I] |
Ok i tried the spray on the intake and it didnt do anything.i talked to a tech. at motorworld chrysler told him what i tried he is stumped. he said mayb it is the #3 inj. and the #4 is not getting the corect psi at idle. t just started to get cold here and it sucks workin on cars i gotta get a new heater for the garage.
hey man hats off to you i just got back from the dealer. it was intake man. gasket its under powertrain warranty so i guess i missed the spot or didnt spray enough when i sprayed it. thanks
glad its fixed !!
| High RPM Miss potential Fix | Exhaust Depot | Turbo Performance | 11 | 15 May 2003 06:31 pm |
