PT Cruiser Forum Car Videos
Custom Wheels
how many miles are on your pt?
  #21 (permalink)
Old 01 Apr 2007, 08:48 am
PT4U2C PT4U2C is offline
Send a message via AIM to PT4U2C
Been gone for a while, thought I'd respond to the miles question.
'01 TE 43K nothing other than oil/filter, ceramic pads, plugs/wires going on now. Still has original battery (built in March of 2000).
'03 Dream just turned 27K, just Mobile 1 /filter changes. Both are modified exstensively, Clearly, the least troublesome cars I have ever owned. Won't buy another one though because I have NO confidence in Chrysler's designers or motives. Mt PT's stay out of dealers.
PT4U2C/1KICKNPT
01 TE Shale Green 17\" Casinos w/Kuhmo 712\'s Bassani,Stull,Full Xenon detailed engine,K&N blane struts: 03 Dream HOT Lot\'s of chrome, Mopar duals, T&T grille,Air raid Blane struts,
autotecnica head/tail light trim, street-rod, turbo badging,auto meter gauges w/pro pod full LED\'s
  #22 (permalink)
Old 03 Apr 2007, 01:21 am
SR-PT4 SR-PT4 is offline
25,000 miles on my 2004 Turbo Lite (automatic, of course). I installed Stage 1 with 2000 miles on the clock and have made close to 50 passes at the drag strip. I've also lowered the car 1.5" front/2.0" rear, added firmer shocks and a rear roll bar, all at around 3500 miles. Swapped out the exhaust with a BTG cat back dual setup with maybe 1500 miles on it. I've also had the car on a road course during a NASAProRacing HPDE track day and pushed it hard. Damn hard. But I change the oil & filter every 3000 miles with Mobil 1 5W30.
Failures to date:
/End list of failed parts.
Yes, that means "nothing has broken". Well, OK, my windshield did lose its life to a ballistic rock, but it's sort of hard to fault the car for that. And I do have this nasty recurring issue where I have to stop every so often to put more gas in the darn thing.
My previous DCX product, a 2000 Dodge Stratus ES V6 was just as lousy overall. But it also burned out a foglight bulb in the 50,000 miles I owned it, so I guess that car was just worthless. Damn these crappy DCX products!!!
  #23 (permalink)
Old 06 Apr 2007, 04:59 am
AA PT AA PT is offline
Failures to date:
LOL
  #24 (permalink)
Old 09 Apr 2007, 09:31 pm
garrettbruce garrettbruce is offline
Smile Re: how many miles are on your pt?
We've got an '04 with the automatic; 33,000 miles.
Toasted a battery
rear wheel bearings replaced
front wheel bearings replaced
lower arm controls replaced
ECM flashed
plugs and wires replaced
(all taken care of under warranty)
replaced front pads; lots of pad material left but there was evidence of "break-up" of the lining!
Bruce Garrett
  #25 (permalink)
Old 09 Apr 2007, 09:59 pm
sawdust123 sawdust123 is offline
Default Re: how many miles are on your pt?
Originally Posted by littleblueGT View Post
My 03 GT w/autostick has 49,500 miles on it now. The trans was rebuilt by the dealer @ 30,000 miles and torque converter replaced. The PCM was replaced around 2,500 and plugs and wires at 750 miles by the dealer. I have changed the cam sensor,oil pressure sending unit, 180 deg. stat, and installed a plastic intake manifold.
Why did you change the oil sending unit. I believe mine may be bad too. My symptom is that the oil light will stay on after a cold start about 50% of the time.
\'03 GT - No mods
\'05 Convertible Touring Ed. - No mods
  #26 (permalink)
Old 09 Apr 2007, 10:03 pm
Almost forgot:
The '03 has 65K on it. I have had a sunvisor and battery replaced under warranty and had the ECM reprogrammed due to the overheating TSB. Other than that it is still going strong. The original plugs and wires are still in good condition. I change oil about every 3500 miles and use Napa Gold filters when I remember to ask for it.
The other day I did have a brake problem. My front caliper must have frozen because only my right front outer pad was worn. All other front pads were at 35%. Unfortunately, the wear indicators are on the inner pads so I didn't notice the problem till I had metal on metal. Luckily, the rotors were salvageable.
My only other complaint aside from the oil light problem in the post above is that one of the headlights is developing haze.
\'03 GT - No mods
  #27 (permalink)
Old 09 Apr 2007, 11:13 pm
delbassman delbassman is offline
Thumbs up Re: how many miles are on your pt?
'03 PT Turbo - Autostick - originally purchased new in 1-03 ... I bought it used in 4-04 with 11,000 miles on it. Now has 43,320 miles - replaced front disc pads with semi-metalics at 32,000 miles ... 4 new Kumho ECSTA ASA's at 36,000 miles ... replaced 2 motor mounts, and serviced tranny at 37,000 ... just had a A/C line replaced under warranty at 43,015 miles. other than that change oil every 3,000 miles with 10-30w, replaced air filter every 15,000 miles ... No other problems.
'03 PT Turbo, Auto-Stick, Steel Blue Paint, Factory Roof Racks w/ Custom Deflector, Light Blue Driving Light Lenses, AOOGAH Horn, Kumho ECSTA ASA- 205/50R-17 M/S
  #28 (permalink)
Old 10 Apr 2007, 07:59 am
tomcruz tomcruz is offline
2003 GT bought in August 2002... 38,000 miles.
2006 GT Convertible.................. 6,000 miles.
2003 GT Turbo
  #29 (permalink)
Old 10 Apr 2007, 08:23 am
MyPTGT MyPTGT is offline
I have an 03 with 54,000. My son has been using it for the last 3 year and I just got it back a few weeks ago.
Don
Live Well, Love Much, Laugh Often
  #30 (permalink)
Old 10 Apr 2007, 10:13 am
tmade tmade is offline
20k on my 05, bought it used and have warranty until 08. So far, knock on wood, no problems. Well that is except the joy of smoking ricers for fun!! LOL
05 Turbo Lite convertible, K&N equipped, Klingons removed, roll bar speakers..more to come
vB code is On
highest miles Mr.2U General Turbo Discussions 8 21 Apr 2007 05:29 pm
UGH! Code 0442, PT Cruiser 2001 LTD, 41,000 miles tvldeals General PT Cruiser Discussions 5 08 Aug 2005 12:46 am
32.9 miles per gallon driving my GT!!! Gary04GT Turbo Performance 26 25 May 2004 06:05 pm
'03 LE Cruiser for sale with 6,500 miles walstib Classifieds: For Sale/Trade 3 31 Jan 2004 08:58 pm
20k miles per year = extra precaution?? alceryes General PT Cruiser Discussions 6 18 Dec 2003 08:17 am
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  Digimon Episodes | Free Ringtone | Mortgage Calculator | Mobile Phones | 0 Credit Cards
