Hello everywon, I have this code showing up on my readout P0325 PCM Knock Sensor Circuit, does anywon know what this means? My check engine light turned on about a week ago and it was only on for one day then it shut off, but I checked it anyway yesturday just to make sure, and this code showed up (P0325 PCM Knock Sensor Circuit)any thoughts on what it might be?
I have a 03 GT and I'm having the same problem. Really not a problem, it runs great. The check engine light will appear two or three times a week . My oil light will do the same sometimes when I first start the car and then I shut it down and restart it, it also disappears. My warranty is still good going to dealer and have it checked out. will let you know what they come up with.
welcome to the two new guys !! i would have the oil lite checked for sure !![^]
Thanks alot guys, that helps me out, Ill keep an eye on it and hopefully it wont come on again, if I does its still under warranty.
Nathan
Car audio and video for 40% to 80% off retail www.benjisbest.com |
Your Knock Sensor is going bad. I am having mine replaced today.
Knock Sensor enables your vehicle to obtain the optimum combination of timing and fuel/air mixture to generate power and efficiency and that means less wasted gas. It keeps fuel from detonating in the cylinder exploding rather than quickly burning as it should. If not replaced a faulty Knock Sensor can quite literally cause hundreds if not thousands of dollars in damage. |
Another 2 year old thread lives again!!!
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Is the Knock Sensor easily replaced or should it be taken to a shop?
Service manual and $40 in parts and a afternoon you will be fine.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though ![]() My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life. |
| spark knock sound under any acceleration | Steve Clark | Tech & Performance Forum | 20 | 19 May 2011 07:01 pm |
| error code p0325 pcm knock sensor circuit? | madchildptgt | Tech & Performance Forum | 0 | 16 Feb 2007 06:16 pm |
| new guy/Spark Knock | Thrusst | Turbo Performance | 7 | 05 Mar 2006 11:26 am |
| S-1 PCM/ knock sensor? | tezz | Stage Turbo Kits | 1 | 09 Oct 2004 12:29 am |
| "Pinging" | kidturbofan | Turbo Performance | 21 | 14 Oct 2003 02:16 pm |
