Plastic Intake Manifold cracked-boost leak!
Old 02 May 2007, 07:33 pm
Default Plastic Intake Manifold cracked-boost leak!
Well I found out why after replacing the MAP sensor there was no performance! There was no visible crack across the manifold, but the main seam on the left side opened up. I found the leak by using bubble leak tester w/ applicator ball. I just spread the liquid along the intake seam, then operated the throttle by hand, and when the boost came up there were bubbles all over the place! I ordered another plastic manifold from Haynes, but if this one acts up I will put the old aluminum manifold back on! At least I feel better knowing what the problem was, and that I can fix it. Saturday I will clean the seam and apply epoxy to hold it until the new manifold comes.
Old 31 May 2007, 03:25 pm
Default Re: Plastic Intake Manifold cracked-boost leak!
Wow, that blows. I would think that if you epoxy the crack and reinforce it with some carbon fiber front and back you would be good to go. No need to buy a new manifold unless Haynes is replacing it for free. If it's a huge crack then forget it.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
Plastic PT Cruiser Intake Manifold Kit hangtym3 General Turbo Discussions 59 11 Aug 2005 09:10 pm
DRILLED INTAKE MANIFOLD FOR BOOST GUAGE amx1397 Turbo Performance 6 24 Feb 2004 02:50 am
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
