New GT owner.
Old 29 May 2007, 02:50 pm
Default New GT owner.
hello, i just bought a 03 GT with 38k miles on it, i like it alot. its pretty peppy, more so then i expected. however my other car is a 350whp awd dsm, and then a 04 r6, soooo, as i expected im going to do some tweaking. anyway, just stopping in to say hi, and thanks for a great forum!
Old 29 May 2007, 04:34 pm
Default Re: New GT owner.
Welcome. I've got friends running 400-500 hp on their PT turbo so have fun tweaking. If it is an autostick you will have to upgrade the auto tranny if you are going past Stage 1 numbers. If it is a 5 speed you will need to upgrade the clutch. Stage 1 is the building block and you just go from there.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 30 May 2007, 01:26 pm
yeah, it is a slush box, only stage 1 number huhs? i was looking at the transmission temps and they really are kinda hot for my liking, i was thinking of putting a larger cooler on it. Also anyone runing water injection on these things? no one seems to make a decent cooler on these things, and that stock turbo is TINY!
one of the questions i did have is has anyone tried to get a dump of the stock vs stage 1 pcm? sure would be nice to find the tables....
Old 31 May 2007, 03:15 pm
Enginerunup makes a good water injector, he's pretty much worked out the kinks in that area. Heres a link to his thread on the subject: My water injection pics
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 04 Jun 2007, 12:38 pm
The code is a very closely guarded secret around DCM. To my knowledge nobody has successfully broken it. The way it is you, can't flash a Stage 0 PCM to Stage 1. Only a company called Flight Systems can create the S1 PCM. You can probably find a used S1 PCM on one of the forums, that is how I got mine, then just sent it to Flight Systems for coding to my car for a few bucks and I was good to go.
Old 18 Jun 2007, 06:08 pm
Fourgasm's Avatar
This guy knows his stuff! Welcome man, when you figure it all out, come make mine faster!!
2003 GT / Bright Silver Metallic / Bought New In 2003 / No Mods
http://www.myspace.com/irishshawneric
Old 19 Jun 2007, 02:17 pm
welcome & enjoy !!
Are you a PT owner or a Chrysler owner? purple04 General PT Cruiser Discussions 55 04 Sep 2014 09:57 pm
Lazy owner Dilly The Detail Shop 16 22 Jun 2006 01:40 am
New owner, new member, just checking in. crzn8r General PT Cruiser Discussions 10 15 Aug 2003 06:28 pm
I'm a new owner!!!!! piffin General PT Cruiser Discussions 10 20 Jul 2003 05:25 pm
Who's the youngest PT Owner ptcruzin42 General PT Cruiser Discussions 21 24 Feb 2003 01:03 pm
