A word to the wise - PT Turbo oil changes
Old 23 Jun 2003, 07:23 pm
Default A word to the wise - PT Turbo oil changes
ALWAYS use an oil filter wrench to remove the factory
oil filter. It is on INCREDIBLY tight - I mangled the he** out of it an hour ago AND ALMOST COULD NOT [xx(]GET IT OFF! So......use a strap wrench or something...you cannot get it off by hand, and puching a screwdriver through it will NOT work. These are cheap, crappy filters, unbelievably cheap when opened up.
http://www.rennstore.com/content/00/...ent/179682.vmg
Craig '03.....now with 10/30 Mobil 1 @ 1,200 miles.
Old 23 Jun 2003, 08:15 pm
I have a filter remover that comes in from the top and has three fingers that collapse on the filter. There is NO space too tight. I'm sure I paid about $10 for it and always works.
Old 23 Jun 2003, 08:42 pm
quote:ALWAYS use an oil filter wrench to remove the factory
oil filter. It is on INCREDIBLY tight - I mangled the he** out of it an hour ago AND ALMOST COULD NOT GET IT OFF!...
Right on--too bad but true. This is not the first time I have read something like this in a forum post--that's why one might want to consider taking your car to the dealership for that first oil change just to be on the safe side.
Old 23 Jun 2003, 09:29 pm
Took my PT to WallMart. Had them put in Mobile 1 and the best Fram
thats on the market. Cost 32 bucks and change and no hassles with the
filter or getting rid of drain oil.
Phil
Old 24 Jun 2003, 10:30 pm
I have found this problem on every new car regardless of make going all the way back to my first new car in 1974. Actually with the PT I was expecting a hassle with the limited room around the filter but it came loose with not much trouble with a strap wrench.
Dave Clement
\'03 GT, Electric Blue
Old 25 Jun 2003, 02:49 am
I went with Mobil1 and K&N Filter. The K&N Filter has a nut welded on the end and open end or cresent work with no problem, after you get the factory one off.
Red
Old 25 Jun 2003, 05:03 pm
I remmeber visiting a site where a guy cut open most of the popular brands. It turns out that one of the best is just a Purolator PureOne. I can't remember if he did a K&N or not. The Fram didn't rate too high.
Old 26 Jun 2003, 09:55 am
Here is the oil filter study. Some good info.
http://www.minimopar.net/oilfilterstudy.html
Don
2003 PT GT
Blow Off Valve Conversion Kit gonzomania Tech & Performance Forum 10 08 Sep 2004 09:08 am
Turbo leaking oil 03baggedturbo Turbo Performance 5 09 Dec 2003 09:54 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
