tach'd up & the "brake light" flashes
Old 02 Jul 2007, 10:47 am
Default tach'd up & the "brake light" flashes
'03 Gt /autostick
At first I thought I was imagining things but my wife confirmed it....
A couple of times when I have had the Gt wound up close to or at red line the "BRAKE" indicator in the lower left hand corner of the tachometer has come on. It goes out as soon as I let off the gas. Has anyone else ever reported this? Thanks!
Old 02 Jul 2007, 12:16 pm
Default Re: tach'd up & the "brake light" flashes
Originally Posted by Hedgapple View Post
'03 Gt /autostick
Wow! That's the first time I've heard of this one. You might have a built in shift indicator light. Call Chysler, get a service tech on the phone and ask him. You got nothing to lose.
2005 GT Cruiser, Cool Vanilla, Automatic, Borla Dual Exhausts, K&N, Navigation and U Connect.
2001 Corvette Convertable, Navy Blue Metalic, Z51, 3:15 with 4" inch quad Borla Stinger Exhausts X Pipe and K&N Filter.
Old 02 Jul 2007, 12:39 pm
Check brake fluid level...it may be sloshing back under max acceleration, causing the 'low fluid level' sensor to trigger the brake warning light.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 02 Jul 2007, 01:36 pm
Yup. It's a classic symptom. As your pads wear, the fluid drops. "Goose" it, and the fluid sloshes enough to uncover the low brake fluid sensor.
Time to plan for new pads.
You probably have about 1/2 thickness left now....
Old 03 Jul 2007, 09:50 pm
Verified..topped off & tested. Mystery solved. Thanks folks!!
