Upper charge pipe SENSOR BLOW OUT!!!!
Old 14 Jul 2007, 12:09 pm
Gold GT's Avatar
Default Upper charge pipe SENSOR BLOW OUT!!!!
Just wanted to know if this has ever happened to any of you. A few days ago I noticed my GT was stumbling alittle if I let if fall from a high rpm to idle. I usually drive pretty conservatively as I live close to where I work so it wasn't really a problem at the time. That night I took it out for a drive to figure out what was going on. As I started to build boost it leveled off at 10psi I usually run 15 or 16 psi so I figured no biggie just a boost leak find where it is and fix it. When I opened the hood the sensor in the upper charge pipe the one with a blue end I believe is a MAF or air temp sensor had blow out and was sitting on top of my intake manifold!! I had just replaced my intake manifold a month ago and had to remove that during the install so I thought maybe I just didn't get it in tight enough. So I put it back in and went on my way again however the next day I was pushing it hard again and it came out again!! I haven't had any problems since but both of those days it was REALLY hot is it possible that this had something to do with it as I noticed that it didn't want stay when it was hot and on cold days it's practically sealed in! I was thinking about putting a very very small amount of silicon on the outside of the rubber grommet for warm days. Has this happened to anyone else and if it has what did you do??
'04 Gold GT 5spd (there is no other way)
Mopar Stage 1 upgrade, Mopar BOV Conversion, AEM CAI, High Flow Haynes Plastic Intake Manifold, MSD High Voltage Ignition Coil Pack, MagnaCore Spark Plug Wires, AutoMeter Boost Gauge, Greddy Oil Catch Can, Hurst STS... Plus a much longer wish list
I DO ALL MY OWN WORK!!
Old 14 Jul 2007, 12:21 pm
Default Re: Upper charge pipe SENSOR BLOW OUT!!!!
No MAF (Mass Air Flow) sensor on our cars, we use a Speed Density fuel injection that uses a MAP (Manifold Absolute Pressure) sensor. You are probably working with the IAT sensor ( Intake Air Temp).
I wouldn't use anything on it but clean the connector and the rubber really well with alcohol to see if that holds it. If you do decide to use some sealant on it get it at an auto parts store and make sure you get one that says "Sensor Safe" on it. Use very sparingly.
Old 14 Jul 2007, 12:44 pm
apexanimal's Avatar
Send a message via AIM to apexanimal
put the grommet in upside down = large side in the pipe, not out of it. this will hold.
'03 GT 5spd: Stage 1+
http://www.cardomain.com/ride/2272425
http://www.ptboutique.com
Old 14 Jul 2007, 12:52 pm
Wow, I thought I was the only one who knew this little trick. It works great, especially on an aftermarket ucp.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 14 Jul 2007, 09:15 pm
Gold GT's Avatar
Thanks for the info esp. the sensor name good to know still kinda learning my PT, had Japanese for way to long. I knew you guys would have the answer headed out right now to fix. THANKS AGAIN!!!!!
Old 19 Jul 2007, 02:29 pm
apexanimal's Avatar
indeed
Old 19 Jul 2007, 06:47 pm
indeed
Leave it to the Crew folks to know what's what.
Old 02 Aug 2007, 04:49 pm
WoW, back in the day, that was part of a dirty word
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 04 Sep 2007, 07:12 pm
i used a dab of superglue on the gromet...issue solved
Old 04 Sep 2007, 11:18 pm
Gold GT's Avatar
Just an update flipping the sensor over worked perfectly!
AGP PT Upper Hard Pipe - NEW PRODUCT RELEASE! Ben@AGP Vendors & Buyers Forum 2 17 Sep 2012 09:41 am
intake pipe for air and throttle ValAir General Turbo Discussions 4 14 Apr 2007 04:30 pm
NEW INTAKE, UPPER CHARGE PIPING 03baggedturbo Vendors & Buyers Forum 71 25 Jun 2004 08:25 pm
Adam's Intake & Upper Charge Pipe - Dyno'd! Mike-in-Orange Vendors & Buyers Forum 39 29 Mar 2004 12:29 am
Turbo Up Pipe Mean Green Turbo Performance 5 04 Jan 2004 05:11 pm
