PT Cruiser Forum Car Videos
Car Rims
Plug change procedure question
  #11 (permalink)
Old 02 Aug 2007, 04:40 pm
OurPTGT OurPTGT is offline
Default Re: Plug change procedure question
it also helps that the plastic manifolds (n/a & turbo) have rubber o rings for gaskets. So no worries there about having to replace them each time. As was stated before, on the plastic turbo unit, you have to be creative and a parkplug socket with a built in swivel is your friend
  #12 (permalink)
Old 07 Dec 2007, 11:33 am
Macguyver Macguyver is offline
2 hrs just to change the plugs, you gotta f---ing be kidding me! I'm trying to do just that and yep I have an '01 non turbo and this will indeed be the first time I've had to do it. What moron designed this engine ? I swear Chrysler must have decided to make simple stuff like this as hard to do as possible for regular folks in order to get you to take it to the stealership. So what do I need to do, take half of the top side of the motor apart so I can get at the plugs and wires?
  #13 (permalink)
Old 07 Dec 2007, 11:46 am
CREWZIN CREWZIN is online now
Yes, but it shouldn't take you two hours. The first time on a non-turbo, of course, will take awhile longer. After that, a plug and wire change can be done in 45 minutes or less because you know the nuts, bolts and tubes that have to come off.
Here's a step by step Imagestation guide to doing the spark plug change. On February 1st 2008 Imagestation is pulling the plug so this guide won't be available after that.
The guide has steps to take off te EGR tube at the back of the upper mainifold. This tube is only on the 2001 and 2002 non-turbo PT. After that Chrysler did away with that tube and you can cut 10 minutes off the change time just for that one tube. It was/is a PITA to get to using two different size nuts (8mm & 13mm I think) and in an awkward place to get to.
Album: CHANGING SPARK PLUGS ON A PT CRUISER - SIMPLIFIED
  #14 (permalink)
Old 07 Dec 2007, 03:01 pm
Thanks. I followed the slide show for changing the plugs and ya it was a bit of a pain getting at the plugs, (never did see/find an erg tube) had to take the bolts off the accelerator cable bracket as well but I was making progress. I actually had the first plug on the passengers side replaced and started to remove the next plug when guess what happened next. The dam plug had been cross threaded into the head and snapped off ! The nut and porcelain (ceramic ?) part came out still stuck in spark plug socket but the rest of the plug is stuck inside the head crap ! Now I guess I'm going to be forced to tow it to a mechanic and have him fix it after all. Ez out, sleeve it and thread it for a new plug. This is getting ridiculous.
  #15 (permalink)
Old 07 Dec 2007, 04:04 pm
Well, ya can't blame that on Chrysler or the guys who built the PT south of the Texas border. Some idiot in a hurry I suppose the last time it was tuned up.
vB code is On
Plug & Wire Change Screw Up???? BB Turbo Performance 12 24 Feb 2007 12:15 am
oil change plug tagreen95354 Exterior & Interior Styling 15 14 Aug 2006 11:56 am
Spark plug change PtCruiserDan General PT Cruiser Discussions 5 22 Mar 2006 06:22 pm
Oil change question. stirfry General PT Cruiser Discussions 8 21 Jun 2004 11:46 am
spark plug change Joe General PT Cruiser Discussions 9 29 Oct 2003 12:21 am
  Cheap Car Insurance | Loans | Personal Loans | Inuyasha Music | Personal Loans
