How difficult is it to change battery cables?
Old 20 Aug 2007, 12:57 am
Default How difficult is it to change battery cables?
My car wouldn't start today and I suspect it was corrosion on the cable going to the starter. The accessories seemed to work fine so I don't think the battery itself had a problem. The car ran fine after a jump start. Although, I may bet a new battery anyhow. This one has 38K miles on it. The original battery only lasted 33K miles.
I had cleaned the battery terminals a few weeks ago but not the other side of the starter or chassis side of cables. My guess is that they probably have corrosion too. Instead of cleaning the cables, I think I'll just replace them. I wore off the outer plating on the terminal side during the last cleaning. I noticed they were very corroded today after just a few weeks.
My questions are as follows:
1) How hard is to change the cables? In others words, is it easy to reach things? I don't have a lift or ramps.
2) What length cables should I get? The partsamerica website showed several lengths from 25" to 60" with several in between.
\'03 GT - No mods
\'05 Convertible Touring Ed. - No mods
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
Possible Battery Problem ? Johns Steel Blue Tech & Performance Forum 2 02 Jul 2007 08:31 am
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
