axle nut torque/ wheel bearing problem
Old 20 Aug 2007, 09:06 pm
Default axle nut torque/ wheel bearing problem
I'm fixing my sister's gt. Her right front wheel bearing went out, or so I thought. Once I had it apart I found the knuckle to be f'd up along with the hub. I did a search and it seems common that the factory didn't torque the axle nut down. In most cars hub/axle nuts require very little torque. I would like to avoid the same problem by correctly torquing the nut down. This problem happened at 34k miles.
Old 20 Aug 2007, 10:20 pm
Default Re: axle nut torque/ wheel bearing problem
I know you just said very little torque in other cars, but from my Haynes manual for Non-Turbo (so maybe it's different):
TORQUE Specification:
Driveaxle/Hub nut ........180 Ft-lbs 244Nm
Old 22 Aug 2007, 04:22 pm
Thanks for the help Crewzin.
Old 28 Aug 2007, 07:38 pm
Torque spec is RFT. The bearing is actually pressed into the knuckle. I do bearings fairly frequently. Get ready for the other one to go bad soon.... Voice of experience.
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
Torque Steering Problem jmlras General Turbo Discussions 12 27 May 2005 04:15 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
'03 with torque converter dampening problem popspt Tech & Performance Forum 4 22 Mar 2003 10:07 pm
