Turbo oil return line leak
Old 03 Sep 2007, 07:53 am
Default Turbo oil return line leak
I noticed while under the car installing another oil pressure sending unit (#2) that there was a leak around the turbo oil return line fitting. I checked to insure that the 8mm bolts were tight, and they were. I don't want to remove the line until I have the right gasket or seal. Has any one else had this happen? Was the gasket special (composite w/copper seal) or just high temp gasket material?
Old 07 Sep 2007, 07:16 am
Send a message via MSN to ddakin
Default Re: Turbo oil return line leak
I've got a 2003 GT and the same thing just happened with mine. The hose developed a leak right at the clamp. It was a quick and relatively cheap fix though.
Dan
2003 PT Cruiser GT
Old 08 Sep 2007, 05:35 pm
I called the dealer, the gasket is $0.25 each, but they have to order it! The gasket will be in tuesday. I'm buying 3 so next time I'll have it on hand. I bet most of the GT's out there are leaking, but you can't tell unless you crawl underneath and look. At 25 cents I don't think it is a special composite gasket with copper sheet etc.
Old 11 Sep 2007, 07:38 pm
Well the gaskets came in, but only 2(I ordered 3). They look larger that the 2 bolt flange from what I remembered. They are cheap and have a thin edge which explains why they will leak. If these are too big I will make my own rather that wait another 4 days for the dealer to order the right ones.You would think that something as important as an oil line would warrant a better gasket!Other GT owners may want to look under the turbo, and check for a leak before they see a spot in the driveway!
Oil Cooler Line leak dpj450 General Turbo Discussions 1 24 Jul 2006 03:50 pm
5 speed 0-60 1quickpt General Turbo Discussions 17 19 Aug 2004 02:57 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
  Find jobs | Wordpress Themes | Debt Consolidation | Find jobs | Sciences in 2007
