2003 MT High Idle
Old 07 Sep 2007, 09:53 am
Default 2003 MT High Idle
2003 Turbo MT 105,000 miles, Stage 1.
The idle speed at rest has increased to about 1500 RPM, however when I am coasting to a stop in neutral or with the clutch in the idle speed is about 2700. When I come to a complete stop it goes down to 1500. There are no error codes.
Any ideas?
Old 08 Sep 2007, 05:40 pm
Default Re: 2003 MT High Idle
Check to see if you blew off a vacuum line, and there are a lot of them!
Old 09 Sep 2007, 09:07 am
i agree some sort of vaccum leak
Old 09 Sep 2007, 07:19 pm
I agree that it seems to be a vacuum leak, but I can't find anything.
I removed, cleaned and replaced the Idle Air Control Valve, no help. I disconnected the IACV and it made no difference.
I checked for codes with the on-acc-on-acc-on trick and got
P-0508
P-0633.
which don't seem to be listed.
I might try replacing the IACV.
Old 10 Sep 2007, 08:15 pm
Do you have the plastic intake manifold? I had one that split at the seams causing a vacuum/boost leak. I found the leak by using bubble leak tester which is just a soapy solution with a fuzz ball applicator. Just apply around the seams and rev the engine, if you have a leak you will see bubbles.Did you reset the computer?
Old 11 Sep 2007, 08:48 pm
I have the aluminum manifold, but I'll try the leak test. I forgot that the manifold is under pressure. (Turbo, duh)
I did not reset the computer. How is that done?
Old 11 Sep 2007, 09:55 pm
P0508 = "Idle Air Control System Circuit Low"
P0633 = "SKIM KEY NOT PROGRAMMED IN PCM"
The SRT guys say that the 0633 is nothing to worry about with engines that are upgraded with "stages" ( PT's only have Stage 1, SRT's have multiple Stages).
Rough Idle on 2003 Pt- Not plugs and wires Jungle Jim Tech & Performance Forum 6 27 Mar 2007 09:22 am
studder at idle on 2003 lowec General PT Cruiser Discussions 4 31 Dec 2005 08:18 pm
New Incentives on 2003 and 2004 Models skylight PT Cruiser News and Rumors 3 15 Oct 2003 12:26 pm
