Loss of power at wide open
Old 10 Sep 2007, 03:20 pm
Default Loss of power at wide open
Having trouble with the 05 GT 5sp.
Been noticing a lower turbo performance and really noticable when getting on the highway in 3rd with the throttle wide open, I have power, but not as much as I remember, and if I back off just a tad, it really wants to go.
Any ideas?
Thanks,
GT is the only way to go
Old 10 Sep 2007, 03:54 pm
Default Re: Loss of power at wide open
Yeah, check your spark plug wires. They may be arcing. Also check your plugs too because if the wires are the problem then sometimes it ruins the plugs as well.
2005 GT Cruiser, Cool Vanilla, Automatic, Borla Dual Exhausts, K&N, Navigation and U Connect.
2001 Corvette Convertable, Navy Blue Metalic, Z51, 3:15 with 4" inch quad Borla Stinger Exhausts X Pipe and K&N Filter.
Old 10 Sep 2007, 10:45 pm
Just changed the wires and plugs 2 days ago and still the same. Also thought the changing of the wires and plugs would make the idling smoother but still has some skipping (not as bad though)
When I'm hard in the throttle it's got power, but if I back off just a bit (like when I'm shifting) I get a real boost (like it should react) It's got more power but not getting it all like I should.
Old 11 Sep 2007, 06:45 am
Next try some fuel injector service and clean the throttle body. Sometimes a buildup of carbon can create the symptoms you have mentioned.
Old 11 Sep 2007, 07:22 pm
You may also have a turbo going bad..... If you are still under warranty take it to the dealership. I would still take it to a dealership anyway. Just mt opinion.
Old 08 Oct 2007, 02:21 pm
Fixed this problem.
Seems that the (spark plug shaped) vac hose was split. This is the one going from the intake side of the turbo (just under the intake on the turbo). Looks like it might be a problem for may other people too.
I replaced it with a spark plug boot and works perfectly. ( the plug boot is exactly the same size and shape only beefyer)
Old 08 Oct 2007, 03:48 pm
Check all of the vac lines and intercooler (IC) hoses for leaks. Boost leaks are not uncommon even from the factory. Use zip ties on vac lines and t bolt clamps on IC hoses.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 09 Oct 2007, 02:03 pm
I agree with Mean Green, check for boost leaks.
Guide: 2006 Power windows and Sunroof always on. zapwizard General PT Cruiser Discussions 3 21 May 2007 09:23 am
Power loss littleblueGT Turbo Performance 3 11 Apr 2006 11:45 pm
Power Loss LoboMXGT Turbo Performance 2 15 Aug 2005 04:00 pm
Power loss? turbomangt General Turbo Discussions 9 28 Jul 2005 12:55 am
Power loss Betsey General Turbo Discussions 5 10 Dec 2003 03:45 am
