Timing belt change
  #11 (permalink)
Old 14 May 2008, 05:06 pm
Location: London, UK with homes in the US and South Africa.
Default Re: Timing belt change
I see some manufacturers are now suggesting timing belt changes after four years - regardless of mileage.
I know the NA PT engine is free-wheeling (so a broken belt is not the end of the world) but what about the Turbo? Doe sit self-destruct?
  #12 (permalink)
Old 14 May 2008, 06:09 pm
Dream4's Avatar
The turbo is also a "Free-wheeling" engine as far as the valve to piston clearance, but at a WOT high rpm belt break there have been a few engines reported head damage with the valves hitting each other (intake & exhaust in the same cylinder when both are fully open)
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
  #13 (permalink)
Old 14 May 2008, 08:18 pm
nevinsrt's Avatar
on my SRT i did the timming belt and waterpump at 60K because the seal on the water pump was leaking causing my engine to run at 220ish when crusing.
now its sitting at 87k with no problems
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
  #14 (permalink)
Old 14 May 2008, 08:21 pm
nevinsrt's Avatar
when changing it, it was a PITA!!!! but took me about 5 hrs
you need a Cirysler pulley puller to get it off
so if it took me 5 hrs on an srt which has a little more room it might take longer to get it done. than again we just got the HO and im still looking to see where everything is at.
Nevin.
  #15 (permalink)
Old 04 Aug 2008, 09:30 am
I have a similar question. I took my 03 PT GT to the dealer because the A/C wasn't cooling. They just called me to say that the A/C suction line needed to be replaced and while they were checking they also noticed that the water pump was starting to leak. Fortunately, those repairs are covered by the extended warranty I bought for the car last year, after the original expired.
The dealer is telling me that since they're replacing the water pump, that I should consider replacing the timing belt as well since they're going to be in there and that it'll cost $334 (the belts are not covered by the warranty).
My car has 60K miles and I put an average of 10K a year. I read that Chrysler recommends changing the belt at around 100K miles.
My question is this: I plan to sell my PT within the next year or 2, so the car should be under 80K by the time I sell it. Do you think is a good idea to replace the timing belt now or should I leave it to whoever will buy the car from me when I sell it?
  #16 (permalink)
Old 04 Aug 2008, 09:38 am
nevinsrt's Avatar
i would have them change it.
if they have to do the pump then do the belt with it.
the belt should be under warrenty you need to check its part of the engine.
and make the whole thing work together.
thats pretty stupid for then to say its not covered.
when i changed my timming belt and waterpump in the SRT. i did it as 60k
Nevin.
  #17 (permalink)
Old 04 Aug 2008, 09:41 am
How/where can I confirm if the timing belt replacement should be covered by the warranty?
  #18 (permalink)
Old 04 Aug 2008, 09:46 am
nevinsrt's Avatar
look at your warrenty broushure and if it says your engine is covered they the belt is too. the belts are part of the engine and the engine cannot function without it.
they have to honor that warrenty and they cant charge you for what your already paying for each month.
Nevin.
  #19 (permalink)
Old 04 Aug 2008, 10:01 am
If you have the powertrain warranty, it's covered provided you are the first registered owner.
Some info .....
Chrysler extended warranty, Factory backed extended warranties for Dodge, Jeep and Chrysler vehicles
  #20 (permalink)
Old 04 Aug 2008, 10:04 am
nevinsrt's Avatar
Some info .....
yup its right on that front page
Parts Covered
The Lifetime Powertrain Limited Warranty coven the parts and components of your vehicle's powertrain supplied by DaimlerChrysler Motors Company LLC:
Gasoline Engine:
cylinder block and all internal parts
cylinder head assemblies
timing case
timing chain
timing belt
gears and sprockets
vibration damper
oil pump
water pump and housing
intake and exhaust manifolds
flywheel with starter ring gear
core plugs
valve covers
oil pan
turbocharger housing and internal parts
turbocharger wastegate actuator
supercharger
serpentine belt tensioner
seals and gaskets for listed components only
EDIT: oh wait yeah what warrenty do you have??
had to reread post...
Nevin.
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 7 18 Jun 2011 01:23 pm
Timing Belt Replacement MarkB Tech & Performance Forum 38 30 Apr 2010 07:38 am
After timing belt change no more Air Conditoning? Ctown General PT Cruiser Discussions 5 28 Mar 2006 01:24 am
when to change Timing belt ? Ctown General PT Cruiser Discussions 4 19 Jan 2006 10:39 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
