Do I need new intake gaskets after this?
Old 15 Oct 2007, 01:36 pm
Default Do I need new intake gaskets after this?
I brought my 03 GT (53K miles) to the dealer to have them look at this vacum cleaner like noise that was coming from the front.
They found leaking intake gaskets and replaced them under my extended warranty but they also found that the car had a lot of carbon buildup and needed a tune up and a transmission fluid flush. They quoted me $730 for it.
I respectfully declined because I got a lower price quote from my regular mechanic (about $500).
This is a newbie question and I apologize in advanced if it sounds dumb but I'm not mechanically-inclined: The intake gaskets there now are brand new after being replaced by the dealer last week but will they need to be replaced again after the carbon buildup is cleaned, the tune up is done and the transmission fluid is replenished or can they be re-used?
Old 15 Oct 2007, 02:17 pm
Default Re: Do I need new intake gaskets after this?
I reused mine in both my wife's non turbo PT and my GT. If you don't know the history of the car I'd have the full tranny service where they actually do a tranny flush and suck out all of the tranny fluid with the machine and change the filter (providing it's an auto tranny).
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 15 Oct 2007, 02:24 pm
I'm the original owner of the car so I know the history. And yes, the tranny fluid will be flushed and replenished.
So no need for new intake gaskets then? The ones that the dealer put in last week should still be good?
Old 15 Oct 2007, 03:17 pm
I have to take the intake manifold off when I change my wife's plugs on her '04 PT. I reuse the gasket. I had my intake manifold off several times on my '03 GT when I did performance upgrade work. I reused the gasket and believeme, with the performance mods I had on the GT I would have known if the gasket went bad. With yours having been replaced quite recently then you should be fine.
Old 15 Oct 2007, 03:31 pm
Great. Thanks Mean Green.
Old 16 Oct 2007, 05:55 am
What are they doing for carbon buildup? Used to be the "highway tuneup" - find an open stretch of road and open 'er up!
Tune up? All there is is plugs and wires - yes, always a good idea, just don't waste money on stock wires (Cranes at www.RaceAndStreet.com ) the stock plugs aren't bad.
If it were me - do plugs, wires, and get tranny flushed. Tranny flush should be about $200. Plugs, wires installed $100 - $150.
BTW - my '05 just hit 55,000 miles - I plan to have tranny flushed.
Old 17 Oct 2007, 01:03 pm
you should be fine !!
Old 22 Nov 2007, 10:17 am
What is the torque spec for intake manifold bolts on the GT????
3.0-inch AGP Intake strangelove Turbo Performance 7 21 Oct 2006 03:52 pm
Intake Manifold Gaskets KingKole02 Tech & Performance Forum 9 17 Jan 2006 03:06 pm
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
pt tuning intake VS Ebay intake gt_tuner Turbo Performance 8 21 Jun 2003 11:41 pm
AIR INTAKE FROM AMX1397 amx1397 Turbo Performance 6 03 Jun 2003 10:22 pm
