map sensor bypass
Old 16 Oct 2007, 10:57 am
JaviPTGT's Avatar
Default map sensor bypass
i was flooring my car and a code can on i want to discount and put the computer on a it said the air/fuel ratio the guy the guy there told me that i need a map sensor bypass so my boost will stay in on spot no jumping from 15-20 can someone help thanks
Old 16 Oct 2007, 11:55 am
Default Re: map sensor bypass
What mods are you running? Are you using a manual boost controller to up the boost levels? If so, you might be running too much boost and the PCM is retarding your ignition timing to keep power output at the target level.
It sounds like the guy referring to the map sensor bypass is recommending a map clamp. It is a simple device that puts a ceiling on the map sensor voltage reading so the computer does not see any boost higher than a set pressure. It's easy to install but you MUST get someone who knows what they are doing to tune the car properly. You are basically bypassing the computers ability to protect the car at high boost. You can literally destroy an engine by messing around with map clamps improperly. You can lean out the fuel mixture by running too much boost and the engine internals will explode. Be careful...
Brian
Old 16 Oct 2007, 02:18 pm
If you get a mapclamp you will need a wideband A/F gauge so you don't lean it out too much and blow your engine. Sounds like you already have a boost gauge? You'll need Stage 1 if you want to spike to 18 and also have more fuel. Before you crank up the boost are you familiar with a turbo?
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Oct 2007, 07:34 am
JaviPTGT's Avatar
where can i get those things at and the mods i have are on my pic in my profile
Old 17 Oct 2007, 08:02 am
I'm not seeing any mods in your public profile. Post them here in the thread so the continuity of the thread will be preserved for later readers.
Do a google search on Map Clamp. You can make your own for a few dollars but I am leary of homemade one's being able to stand the engine compartment heat. You could mount it in the passenger compartment though.
Brian
Old 09 Mar 2009, 04:49 pm
JaviPTGT's Avatar
hey i just got my map clamp in the mail it has 3 wires on it. i just need to know what the 3 wires on the map senior is so i can connet to the mapclamp. Pic will help better thanks
Old 09 Mar 2009, 05:23 pm
Do you have a wideband air/fuel gauge installed?
Old 09 Mar 2009, 09:16 pm
JaviPTGT's Avatar
not yet i order it it should be here in about a week thats why i want to get the info so when it comes i can put it all together
Old 10 Mar 2009, 02:11 am
Ok, don't blow your motor up.
This is for a srt-4. I don't have a GT to look at so I can't tell you if the wire colors are the same. Should be. HOW-TO: Build/Install/Tune Map Clamp - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
  Debt Consolidation | Wordpress Themes | Premium wordpress themes | PT Cruiser | Real Estate Articles Directory
