are there any vacuum/pressure tubes that can be disconected to trick obd computer
Old 23 Oct 2007, 10:03 am
Default are there any vacuum/pressure tubes that can be disconected to trick obd computer
i see alot of small hose tubes on turbo engine . a few on the turbo itself . can any of them be removed / capped off or reduced flow to trick the computer to allow more boost ?
Old 23 Oct 2007, 06:37 pm
Default Re: are there any vacuum/pressure tubes that can be disconected to trick obd computer
Good question I'd like to know too.......
MODS:
-06 PT/GT
-S0
-Intake
-3" exhaust
-Eibach springs
-5% tint
-Tinted tails
Old 23 Oct 2007, 07:12 pm
If you want to trick the computer into higher boost then get a boost gauge, a wideband air/fuel gauge and a mapclamp. You just can't go to higher boost without knowing the air and fuel mixture. Run too lean and you'll destroy your engine.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 24 Oct 2007, 10:36 am
Putting a manual boost controller will allow you to run more boost up to a point. I ran an MBC at 15psi on my car with stage 0. I threw an overboost code one time while at wide open throttle getting on the interstate. I hated the part throttle overboost so I removed it. Stage 1 will allow higher boost levels without throwing codes, but you still need to be careful. If you crank the boost too high and the computer can't supply enough fuel, you'll run the air/fue mixture too lean and could possibly cause MAJOR engine damage (BOOM!)
