Turbo Replacement Question
Old 28 Nov 2007, 10:11 pm
Default Turbo Replacement Question
My stock turbo went bad. The turbine on the exhaust side snapped off and there is not much left of the fins and the other one has curled fins on it. Not sure what may have caused this? Well, I need to replace it and was wondering if I have to replace the turbo along with the exhaust manifold or can I just replace the turbo? I had read somewhere that you have to replace them connected together as an assy. because the turbo will leak if you just replace the turbo alone. Is this true or can I get by with just replacing the turbo alone? I also can not find a tourqe spec for the clamp bolt if just replacing the turbo only. Anyone familiar with replacing a bad turbo? Any and all info and tips replacing the turbo would be greatly appreciated. Thanks, Brad.
Old 29 Nov 2007, 05:47 am
Default Re: Turbo Replacement Question
Replace Turbo only,,, I have to check,,, but I may have access to a brand new assembly. PM me if interested.
Tom
Old 29 Nov 2007, 05:36 pm
I am interested in the new replacement assy let me know how much,etc. Thanks, Brad.
Old 02 Dec 2007, 03:51 pm
overboost's Avatar
Location: Flint MI #3 in violant crimes, #2 in unemployment
the last time I seen one break like that was when I was going 140 down the highway in my shelby daytona, let off the gas, didnt push in the clutch and heard a cool sounding BOOM followed by a interesting POP.
needless to say the IC filled up with oil in about 10 seconds, got off at the exit about 15 seconds after that.
towed it the rest of the way home.
by the time you read this, I will have spent another $500 on this stinking car.
Old 04 Dec 2007, 07:53 pm
You will have to replace the manifold and turbo as an assembly. Also a good idea to replace the oil lines to and from the turbo.
Old 03 Jan 2008, 02:57 am
cdd's Avatar
cdd cdd is offline
If you need a exhaust manifold due to damage caused by turbine hitting the scroll let me know, I have a new one with gaskets and oil return that I'll sell cheap.
2004 PT PLATINUM Lite
Auto | S1 | S2 injectors | K&N FIPK | Hexalogger | S2 wastegate controlled by PCM | 3"o2 | 3"cat | 3"DP | 2 1/4"catback | plastic intake | W/I | DSP Nemo/MM tune | Black ES MM Inserts |
13.89@100.96(1/2 tank E40 fuel, w/i, back seats and spare out, 17" street tires, DSP controlling S2 wastegate)
Old 06 Jul 2009, 07:12 pm
im just changing the turbo on mine alot easyer then taking the manny off. on my neon with the srt turbo on it i never had any problem with the turbo leaking.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=10114&dateline=124268  4992
Old 06 Jul 2009, 07:14 pm
wow didnt see it was a old post lol
Turbo Brake System Question R_I_PT Turbo Wheels/Suspension/Handling 5 03 Nov 2007 07:44 am
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Hahn Turbo Install Question PuterTater Cruiser Tech & Performance Forum 1 02 Oct 2002 09:26 pm
