PT Cruiser Forum Car Videos
Car Rims
will wraping the turbo pipes stop balloning
Old 12 Apr 2008, 12:36 pm
mino mino is offline
Default will wraping the turbo pipes stop balloning
aside from paying a few hundred for hard pipes - can we wrap them in black duct tape or heat tape to stiffen them - or is this a bad idea - ( not to concerned on looks )
Old 11 May 2008, 12:28 am
Taggert_LOA's Avatar
Taggert_LOA Taggert_LOA is offline
Send a message via AIM to Taggert_LOA
Default Re: will wraping the turbo pipes stop balloning
it's not just balloning but also the collapse of the lower pipe especially. i'd start with switching that pipe, and work on the others as you can afford them
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 11 May 2008, 04:49 pm
AlexJB's Avatar
AlexJB AlexJB is offline
Send a message via Skype™ to AlexJB
You should give it a try.
The only negative is adding a few grams weight and reducing the heat radiation co-eficcient of the hose, which is poor compared to steel tube anyway.
Many of the hydraulic systems I worked on used to use once peice moulded hoses and I borrowed some of them for my turbo'd ford, worked well. anything that's designed to be stiff and take 35psi would work.
When added an intercooler to my turbo set up on my ford I mocked up and even ran for an hour with my borrowed CAT hydraulic hose peices and plastic stuff from a home improvement store, think it was for chemical toilets!
To be old and wise, you must first be young and stupid.
vB code is On
Turbo Replacement Question PTCruzzn General Turbo Discussions 5 03 Jan 2008 02:57 am
Turbo leaking oil 03baggedturbo Turbo Performance 5 09 Dec 2003 09:54 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
  Loan | Problem Mortgage | Funny Videos | Mortgages | 0 Credit Cards
