PT Cruiser Forum Car Videos
Car Rims
ceramic vs. semi-metallic brake pads
Old 01 May 2008, 06:07 pm
pppt03turbo pppt03turbo is offline
Default ceramic vs. semi-metallic brake pads
hi all - after 39,000 miles, i need new brake pads. i want to go ceramic, but the parts guy said semi-metallic is the way to go, as they are easier on the rotors. i guess the ceramic pads (because they are so hard) cause hot spots on the rotors - which in turn - causes warpage. anyone out there know the scoop on ceramic vs. semi-metallic pads?
gt model, aftermarket air cleaner, magnecor plug wires, tyc b/up lenses, chrome grille kit, apc retro 3d taillights painted steel blue, buick-style portholes
Old 03 May 2008, 11:16 am
Hoot23 Hoot23 is offline
Default Re: ceramic vs. semi-metallic brake pads
I've been using 100% ceramic. The brake dust problem is almost nil and no squeaks. No rotor problems yet but stock rotors are not expensive.
Old 03 May 2008, 11:57 am
bobs turbo pt bobs turbo pt is offline
put ceramic on wifes pt no problems and no DUST !! the best part lol
Old 03 May 2008, 11:03 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Red face Re: ceramic vs. semi-metallic brake pads
The dust on the front really sucks!
I will go ceramic at the first opportunity.
Frank, aka SOONERCRUISER, and the Black Sheep
http://ptcruiserworld.tenmagazines.com/ew/mygallery.asp?id=4002
Old 04 May 2008, 09:06 pm
Agree with others. I have ceramics on mine and no dust is great, and no problems.
I had ceramics on my '02 as well. Put them on at about 30,000 miles, and replaced disks (with new pads) at about 80,000 miles. Never had any problem.
Old 05 May 2008, 12:35 pm
thanks for everyone's replies. i decided to go with semi-metallic (the type of pads that came with the car).
actually, i had to do the front brakes twice, because the raybestos pads came with new aluminum channels. these are what each end of pads ride on. after installing everything, the test ride yielded massive sqeaking. i turned around and popped the wheel off. turns out, the new channels were not as wide (by a 1/4+"!) as the stock ones. so, i cleaned up the old ones and swapped them out. no more sqeaking. i don't know if this was packing mistake by raybestos or if they did not consider that gt's have larger brake calipers.
anyway, if you buy front raybestos pads, make sure the aluminum channel ends are wide enough. otherwise, you will be doing your brake job twice.
Old 05 May 2008, 07:56 pm
Those are stainless steel shims...
The GT has bigger rotors, and they always send shims for the standard disks.
I cleaned and re-used the original shims, too.
Old 21 May 2008, 08:00 pm
R_I_PT R_I_PT is offline
I put ceramics on mine with stock front rotors and I will never go back to cruddy OEM pads.
I'd rather throw the low $$ for new rotors than deal with the dust noise and cruddy pads.
Old 22 May 2008, 02:52 pm
nevinsrt's Avatar
nevinsrt nevinsrt is offline
im going with Hawk Ferro-Carbon pads
"race-level" braking = increased rotor wear, noise, and dust
I will never go back to semi-metallic or ceramic again.
it doesnt compare to the stopping power
it makes the car feel like a BBK was installed
brake dust is an optional and stylish
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
Old 23 May 2008, 01:20 am
hoppyloop hoppyloop is offline
Send a message via MSN to hoppyloop Send a message via Yahoo to hoppyloop
How about green stop pads are they good
vB code is On
Front ceramic front brake pads coopj40 General Turbo Discussions 1 17 Mar 2007 06:42 pm
Morse ceramic pads? Hill Cruiser General PT Cruiser Discussions 7 15 Aug 2005 04:44 pm
Akebono Ceramic Pads for 03 GT mangusta1969 Turbo Wheels/Suspension/Handling 11 03 Oct 2004 06:04 pm
Friction Master Ceramic Brake Pads Hooligan Wheels, Tires, Suspension 3 29 Jun 2004 10:19 pm
Ceramic Brake pads? PT-GTA Turbo Wheels/Suspension/Handling 18 13 Feb 2004 05:30 pm
  Mortgages | Buy PSP | Remortgage | Current Accounts | Pay Day Loans
