PT Cruiser Forum Car Videos
Car Rims
WGA Question
Old 11 May 2008, 07:47 am
03greygtcruiser 03greygtcruiser is offline
Default WGA Question
I just installed my stage 1 and i tried a wga that i bought at a local speedshop, however it works exacally like the agp one but i could not get the thing to work i played with it for hours adjusting it but i guess am too stupid cause it never worked ,long story short i got frustrated and put the stock one back on, so here's my question could i put the S2 WGA on with the S1, and if i could does it have to be adjusted or can i just throw it in there like the stock one. OH BTW before i got the S1 i called HAYNES they wanted to charge me 700something dollars for the s1 then i found jegs.com and i was able to get it for 573 next day shipping for only 10bucks and a free mopar BOV, cant beat that. Thanks in advance!
Current mods- Stage 1, Big FMIC, 3" DP and 3" turbo back exhaust, Boostcontroller @ 17psi, Motormount inserts, BOV and 3" intake.
Old 12 May 2008, 09:13 pm
03electricbluegt 03electricbluegt is offline
Default Re: WGA Question
You can add the S2 WGA to your car but you need to adjust it. Make sure you have a boost gauge and you preset the tension on the WGA as low as it will go and go up from there.
Old 12 May 2008, 09:44 pm
But is it easy or a mission like the agp one, just one knob or two thanks and am sorry for the questions but i want to be sure, and yes i have a boost gauge
Old 13 May 2008, 10:08 am
Adjusting any WGA on the PT is a chore due to the heatshield and the heat of working on it after running it. You might be able to temporarily remove the heatshield until you get things dialed in but I would limit the amount of driving you do with the shield off. The stage 2 WGA is adjusted with a threaded link on the end of the WGA arm and a jam nut to keep it in place.
Good luck
Brian
Old 14 May 2008, 11:43 am
nevinsrt's Avatar
nevinsrt nevinsrt is offline
the problem with the AGP is you will have to by pass some sielnoids and run the WGA stright off the turbo (basicly taking the boost off PCM control)
then it should work
the S2 WGA will work on you car and do what ^^^^ said about the adjustment and watch your gauge
Nevin.
03 SRT-4
05 GT Cruiser H.O.
68 Mustang Coupe
Old 14 May 2008, 01:30 pm
Mean Green Mean Green is offline
Good luck
Brian
On the PT some people cut the heatshield a bit so the wga can be adjusted with everything intact.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 15 May 2008, 11:02 am
thanks for all the help i think am going to get the s2 wga
vB code is On
PT / SRT-4 Rear Sway Bar Question Maxxam Turbo Wheels/Suspension/Handling 11 13 May 2008 02:29 pm
Question and an Idea on Speakers nozzano22 Sound and Security Forum 5 21 Jul 2004 11:38 am
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
Have a question for Andy Gorlich Capt Kidd General PT Cruiser Discussions 0 30 Mar 2004 10:18 pm
trany fluid question Jimbo General PT Cruiser Discussions 10 21 Jan 2004 04:01 am
  Mortgage | Problem Mortgage | Comprar vivienda Denia | Cheap Car Insurance | Indoor Flags
