PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   General Turbo Discussions (http://www.ptcruiserlinks.com/forum/general-turbo-discussions/)
-   -   Autometer air/fuel gauge # 4375 question (http://www.ptcruiserlinks.com/forum/general-turbo-discussions/18053-autometer-air-fuel-gauge-4375-question.html)
dc3_1132 14 May 2008 10:19 am
I am thinking about buying one of these gauges. I was wondering if anyone else has installed one of these on their PT? Will it work on the stock narrow band O2, or do you have to buy the adaptor ( #2244) to make it work correctly? The adaptor kit costs more that the friggin gauge does!!
If you do have to use the adaptor kit I will probabaly hold off and get a wideband kit.
dc3_1132 06 Oct 2008 10:07 pm
Re: Autometer air/fuel gauge # 4375 question
Anyone??????
Zoowackery 09 Oct 2008 06:18 pm
This is what Autometer said:
The PT Cruiser's factory O2 sensor is not compatible with a narrowband air/fuel gauge. It's actually a bit of an anomaly as far as O2 sensors go, as it shares some characteristics with a wideband O2 sensor, but reads like a narrowband. Because of this,it actually won't work either way. You will need to add a weld in bung to the exhaust system (pre-catalyst) to use a gauge like this. On a narrowband unit, you'll want to use our 2244 kit (although most factory narrowband O2 sensors will work). On a forced induction vehicle such as yours, you will be much better off using a wideband like the 4378. This will give you realtime measurements of the mixture. This makes it an
invaluable tuning tool for setting fuel/boost curves. The narrowband units serve as a good warning when the vehicle is about to go lean, the wideband shows you what's actually going on. Hope this is helpful, let me know if I can be of further assistance.
Best regards,
Joseph Mills
Auto Meter Products, Inc.
Hope it helps.
Mean Green 09 Oct 2008 06:20 pm
The PT needs a wideband like this
RAGE-TEK :: Interior and Gauges :: AEM UEGO wideband
Mean Green 09 Oct 2008 06:22 pm
On the PT the narrow band is just a light show. :(
dc3_1132 09 Oct 2008 07:45 pm
DAMNIT!!!! :angry:
I already bought one!!
I guess I could put it in my Neon? Will it work on my Neon?
Zoowackery 09 Oct 2008 08:22 pm
Where are you going to install the O2 Sensor for the gauge?
dc3_1132 09 Oct 2008 08:35 pm
Would it not wire into the narrow band O2 on the Neon either?
