does the gt have something called a map sensor??
Old 25 Jul 2003, 01:05 am
Default does the gt have something called a map sensor??
hello all, does the gt have something called a map sensor?? a friend says it could be that doing this problem to my car but i don't know what that is?? any ideas ?? thanks
Old 25 Jul 2003, 01:48 am
Yes it does, it is the sensor on the intake manifold on the pass. side where it merges into 1-4 hope this helps
Old 25 Jul 2003, 12:10 pm
MAP = Manifold Absolute Pressure Sensor
There is also a TIP sensor (another presure sensor)
These guys are not cheap usu about $100 (slightly less)apiece and not reusable for the dealership if the problem isn't solved.
Old 29 Jul 2003, 11:05 pm
i wonder if the map sensor is bad would it do what is happening to my car??
Old 30 Jul 2003, 12:54 am
ok, yes it has both map and tip pressure sensores. How ever, the map sensor actually is mounted on the fender well or fire wall and a vaccum line runs from the manifold to it. The vacuum line relays presuure to it, tells the sensor how much vacuum or boost the engine is experencing. If it is bad, the computer will go into a limp mode, use look up tables, turn on the check light, and should limit boost. That is my guess, based on how the older eighties turbo chrysler / dodge were programmed.
As for the sensor on the manifold, where it splits from 1 to 4 runners, that is your charger air temp sensor. It tells how hot the boosted air is.
88 Daytona Shelby Z T-II Blue
88 Daytona Shelby Z T-II Silver T-Tops
89 Caravan ES Turbo-I
03 PT GT Turbo 41TE Autostick Electric Blue
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
