OK - Now I have the steering noise. Is the R&P replacement the cure?
Hate going to my 5 STAR dealer unless I have back-up of what others have experienced. My 5-Star dealer is full idiots. [xx(]
![]() \'03 GT Inferno Red AutoStick - Stage 1 - Air Box Mods & K&N Filter - AMX Intake Down Pipe - Flowmaster 40 Series Exhaust - Magnacor 8.5mm Ignition Wires - Pin Stripping - Chrome Side Spears - Chrome Tail Light Covers - Chrome Fuel Door - E&G Custom Grill - Painted Rear Mud Guards - 3-D Liquid Flames - Chrome/Red Neon Washer Nozzles - Interior Neon |
Mitch
Which noise are you experiencing?? The "nylon rubbing" noise as you turn from side to side? Or the Whistle?
![]() -------- 2003 Silver GT PT Cruiser 3rd Brk cling, APC GEN2 Eurotails. BTG Intake. StreetGlow Gold Series underglow kit \"Green\". BTG Strut tower Brace. |
I have a 2004 pt with 5,000 on it and the past few days I have been noticing that whistle sound and it looks as if the sound is comming from the rack area were the hoses cannect. Will be taking it in on friday to have them look at it...
For the people with the whistling noise, try this TSB:
NUMBER: 19-001-04 GROUP: Steering DATE: Mar. 16, 2004 This bulletin is supplied as technical information only and is not an authorization for repair. SUBJECT: Whistling Sound When The Steering Wheel Is Turned OVERVIEW: This bulletin involves installing revised power steering hose assembly. MODELS: 2003 - 2004 (PT) Chrysler PT Cruiser NOTE: This bulletin applies to vehicles equipped with 2.4L Turbo engines (sales codes EDV or EDT). SYMPTOM/CONDITION: A whistling sound that increases in intensity when steering input is made. The higher the torque required to turn the front wheels, the louder the sound. DIAGNOSIS: Let vehicle warm up for a minute then turn the steering wheel; the intensity of the sound will be proportional to the torque required to turn the front wheels. The intensity of this sound will NOT be dependent on engine RPM, only minor frequency changes will occur with RPM changes. If the whistling sound is heard when the steering wheel is turned, perform the Repair Procedure. PARTS REQUIRED: Qty. Part No. Description 1 05272319AJ Assembly, Power Steering Hose REPAIR PROCEDURE: 1. Replace the power steering pressure & return hose assembly with a revised assembly, p/n 05272319AJ using the procedures outlined in the Service Information on TechCONNECT. Use the following specifications for tightening the hose fittings: FITTING LOCATION TORQUE SPECIFICATION Gear End Return Port 26 - 29 Nm (230 - 260 in. lbs.) Gear End Pressure Port 31 - 35 Nm (275 - 310 in. lbs.) Pump End Ports 31 - 35 Nm (275 - 310 in. lbs.) |
Thanks for the info....thats sounds exactly what mine is doing. I really dont want the rack replaced if they dont have to and the problems does not get corrected...I will take this TSB in on friday when I go the the dealer here in Louisville. Again Thanks for the fast and detailed reply....
For the people that have that clunky noise for steering, here is a thread from another forums:
http://www.ptenthusiasts.org/PTForum...light=steering |
Just curious. Has anybody had the TSB mentioned a few posts ago about the whistle problem done? Did it work??
OOPS. PTGT BOY described it. If you have a 2003 turbo, this is your problem.Does this describe your problem?
I had this issue, had the hose replaced and now all gone. Did not require ATF fluid change, cause you have it in there. Brought the TSB to the dealer. NUMBER: 19-001-04 GROUP: Steering DATE: Mar. 16, 2004 This bulletin is supplied as technical information only and is not an authorization for repair. SUBJECT: Whistling Sound When The Steering Wheel Is Turned OVERVIEW: This bulletin involves installing revised power steering hose assembly. MODELS: 2003 - 2004 (PT) Chrysler PT Cruiser NOTE: This bulletin applies to vehicles equipped with 2.4L Turbo engines (sales codes EDV or EDT). SYMPTOM/CONDITION: A whistling sound that increases in intensity when steering input is made. The higher the torque required to turn the front wheels, the louder the sound. DIAGNOSIS: Let vehicle warm up for a minute then turn the steering wheel; the intensity of the sound will be proportional to the torque required to turn the front wheels. The intensity of this sound will NOT be dependent on engine RPM, only minor frequency changes will occur with RPM changes. If the whistling sound is heard when the steering wheel is turned, perform the Repair Procedure. PARTS REQUIRED: Qty. Part No. Description 1 05272319AJ Assembly, Power Steering Hose REPAIR PROCEDURE: 1. Replace the power steering pressure & return hose assembly with a revised assembly, p/n 05272319AJ using the procedures outlined in the Service Information on TechCONNECT. Use the following specifications for tightening the hose fittings: FITTING LOCATION TORQUE SPECIFICATION Gear End Return Port 26 - 29 Nm (230 - 260 in. lbs.) Gear End Pressure Port 31 - 35 Nm (275 - 310 in. lbs.) Pump End Ports 31 - 35 Nm (275 - 310 in. lbs.)
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
I had to have my steering rack replaced. The noise got progressively worse and started to leak fluid. No problems now in the last 10,000km.
Don
\'03 Inferno Red 5 spd. Hurst shifter,Loaded |
All,
I, too, had these problems. Something to check: Look at the power steering lines going to and from radiator (lower left and right). If you see fluid, a "wet" hose, or road grit clinging to the metal couplings, you probably have a leaking steering rack. Mine was replaced after noticing the fluid on the hoses. I also had the power steering hoses replaced under warranty. I have lost the "nylon rubbing" sound since the replacements were made. Scott
\"If you choose not to decide, you still have made a choice.\" |
| steering problems: 2005 convertible | bobsackaminnow | PT Cruiser Convertible Forum | 0 | 13 Sep 2006 06:56 pm |
| Steering Feel | rszappa1 | Turbo Wheels/Suspension/Handling | 3 | 05 Mar 2006 05:23 am |
| Shaking Steering Wheel | GAHOO | Turbo Wheels/Suspension/Handling | 8 | 14 Jun 2004 11:22 pm |
| Major Turbo problems | Iris | Turbo Performance | 7 | 04 May 2004 07:06 pm |
| Power steering leak . . . | gonzowing | Tech & Performance Forum | 5 | 15 Apr 2004 10:28 pm |
