Stock wires suck. If using the stock Copper Plus plugs then gap at .035.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
If you do the wires (and maybe plugs at the same time), how about taking off the negative battery cable for a few minutes so when you put it back together the computer can learn about any new adjustments. Can't hurt.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() Visit My Home Page www.CREWZIN.com |
#1 It may be and is most likely the PCM needs to 'relearn' for the change of 'conditions' that has occurred. Manly back pressure difference.
#2 It MAYBE the converter is partly clogged and under boost and cant flow...I guess the blow off valve would go off constantly if that where the case??? Let us know if the relearn does it or not.Go from there.
2001 Limited Edition N.A./Auto 3/4 inch rear drop. K&N Drop in. InDash Pioneer DVD Stereo Our Photography |
What plugs do you have and what are they gapped at? Sounds like the high rpm stutter.
{Mean Green} I don't know what kind of plugs are in it or what they are gapped at. I have only had the car a month and half or so. Better plugs/wires were on my list of "to do's" anyway. {OCCrewzR} I don't think the converter is partially clogged because the BOV acts exactly the same with the Magnaflow catback as it did with the stock exhaust. The car only has 31K miles on it. I wouldn't think the cat could clog up with only 31K miles on it. I would also think if the cat was getting clogged, it would have acted up with the stock muffler on it. (Could be wrong) The car NEVER cut out/sputtered/hesitated until I put the catback on it. I do have a little bit of an exhaust leak where the new midpipe connects to the back of the cat. It sounds like poop, but it shouldn't have any effect of the way the motor runs. I had thought about pulling the negative wire off, but I figured the PCM would relearn itself after driving it a couple times. My Neon has never had a problem with any upgrade I have made to it. Actually, shortly after I put my CAI on it, I had a check engine light. All I had to do is drive it around for an hour or so to let the PCM figure out I had changed something and the CEL went out and hasn't came back on since. I didn't have any problems when I put the K&N filter in it and did the airbox mods on the PT. Also, no problems with the 3" charge pipe upgrade. I will pull the battery cable off and give it a try. It can't hurt anything to try. ![]()
'04 Dream Cruiser 3 #1132 of 1309 31K miles, 5-speed, H.O. turbo Mods (so far): Stage 1, Airbox mods, K&N drop in, 3" charge pipe, Mopar BOV, Magnaflow 2.5" catback. Wanted Mods: Upgraded intercooler piping, A-pillar pod and guages, who knows what else.
The reason I asked about the plug gap is because my brand new '03 GT had the high rpm stutter that the dealer could not figure out. It did not stutter when you did not get on it, only when you really pushed it. A friend told me to drop the stock .050 plug gap down to .040 and the stutter disappeared. When you go stage 1 I'd try .035 for the gap.
I will still try the resetting of the PCM first. I still don't understand why this started after switching exhaust. It just doesn't make any sense to me how a better flowing exhaust would make the car run worse.
| Psi-Fi PowerPaq installed. WOW!!! | ksquared11 | Turbo Performance | 17 | 13 Jan 2008 04:26 pm |
| 2004 Dodge SRT4 FS Chicagoland w/Chromoly roll bar installed! | newbee101 | Classifieds: For Sale/Trade | 0 | 08 Nov 2007 02:15 pm |
| Pillar Pod and Gauges installed | Mean Green | Turbo Performance | 25 | 12 Nov 2004 01:38 am |
| Roof Rack "factory installed" for GT | KevinM | Exterior Accessories Forum | 9 | 11 Apr 2004 12:25 pm |
| TurboXS RFL BOV and AGPTurbo BOP installed!! | RobGT | Turbo Performance | 1 | 23 Jun 2003 05:38 pm |
