replacing oil filter only
Old 30 Jul 2003, 09:54 pm
Default replacing oil filter only
Is this possible? I have 1200 km now on my GT and wants to replace oil filter only for now and change both oil and filter at 3000km.
I did notice that the oil filter location is at the bottom in line with oil pan. I am not sure if oil in the pan will come out as well.
I must say, I absolutely love my GT and although I drive it hard, I want it to last long as possible.
Old 30 Jul 2003, 11:05 pm
The oil in the pan shouldn't drain if you just change the filter. I've gotta ask though, why? If you're already down there with a filter wrench and a drain pan, why not drain the oil and replace with fresh?? Oil is cheap, engines aren't. Add a 13MM wrench to your stuff and drain it all!
Joe
[:I]
USA- Love it or Leave it!
Old 30 Jul 2003, 11:48 pm
Oil filter is in a same level as bottom oil pan. So is there like valve that stops oil from oil pan coming out of the filter hole. I am going to take out the filter and find out.
I love to replace both oil and filter, but with lot of talk about factory oil containing additives to assist in proper break-in, I want to leave the original oil in till at least 3000km. I personally do not believe everything I hear about proper break-in procedures, but with most people changing first oil and filter at 5 to 6000km, changing filter at 1200km ( also have big magnet on the filter to contain most of metal fillings inside the filter) and changing oil and filter at 3000km will be more than enough. At 6000km, another oil and filter change, and change every 4000km till 15000km. Than, switch over to Mobil 1.
03 Silver GT Turbo 5-Speed
Old 31 Jul 2003, 11:00 am
I changed my oil and filter at 600 miles. The SRT4 using the same engine as our PT GT has Mobil 1 from the factory so there should be no break in worries. Mine had some metal shavings at 600 so do not wait.
Don
2003 PT GT
Old 31 Jul 2003, 11:55 am
We made our first oil change at 1000 miles and went immediately to synthetic oil. Every 3000 miles thereafter, it will get an oil and filter change. Repeat, oil is cheap, engine are NOT!
Joe
Old 31 Jul 2003, 12:02 pm
I switched to Mobil-1 last week at 5730 miles. I will be changing oil & filter every 3000 from here on out.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
Old 31 Jul 2003, 12:11 pm
If you remove the filter No aditional oil will escape. If you look at it closer you will se that it is not conected to the crankcase. It is an oil cooler/filter, There are two lines conected to it, one goes to the fuel pump and the other one goes to the turbo bearing cartridge, then to the engine.
When I changed the oil last week, I first removed the filter, a few drops fell for a while but then it stopped. Then, I proceded to open the oil crankcase bolt and let all the black crap out of there. Cosed it after three hours of dripping, replaced the filter and filled with Mobil 1.
Old 31 Jul 2003, 12:24 pm
Wow, wish I could wait three hours for the pan to stop dripping
Hopefully, after waiting 10-15 minutes, enough of the old oil is out of there that it won't cause any problems.
Old 31 Jul 2003, 12:55 pm
Ian,
If you really want to de-gunk your engine why don't you put new oil in, let the engine run for 10 minutes, then drain and refill again?
Old 31 Jul 2003, 01:17 pm
Try loosing the oil filler cap since it is a closed system. May find the oil drains a bit faster.
Cabin air filter AlmondTurbo General PT Cruiser Discussions 36 07 Sep 2011 07:58 am
Watch out K&N! azptcruiser Non-PT Discussions 3 01 Apr 2004 11:55 am
Oil & Filter Change. one_fast_pt General Turbo Discussions 13 17 Jan 2004 02:32 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
