Originally Posted by 4SPEED
more often than not when at a stop and idleing the engine runs ruff. Not like a spark plug missing but definately noticeable. And it may vary in intensity from stop to stop or may not do it for awhile but I never feel anything driving (accelerating or cruising). The plugs and wires are new. I have run several bottles of Techron thru to clean the injectors and carbon off the valves and piston crowns. The compression is 169, 172, 174 and 173.
I'm just fishing to see if anyone has had a similar problem or has any ideas before I take it to a shop and have to hock my wife for the bill. It's an 03 GT with 51125 on the odometer.
Could it be a bad injector to have a problem come and go? Are they hard to replace and what is the cost of one or should you replace all at the same time?
thanks guys
Hi
I just had the same problem fixed in my 04. It idled very rough and and was misfiring. It would actualy stall at times.
My dealer had a heck of time finding the problem. Car was in shop for 4 days.It turned out to be a faulty 02 sensor. That is the one that is after the Cat. converter. Part # 56029050AA
They replaced the plugs and wires but that didn't solve the problem till they located this bad sensor.
The sensor was causing the car to run far to rich.
Hope this helps
