Oil drops under car
Old 03 Aug 2003, 09:50 pm
Default Oil drops under car
I have an automatic and found a small amount of oil under the front of my car. There were 2 drops on the black pan, not the oil pan, I guess the automatic. I wiped it off and will be watching it. Anyone have this problem? Thanks[:I]
Old 04 Aug 2003, 11:38 am
what color was the fluid?? have you had an oil change recently??
Old 04 Aug 2003, 04:37 pm
When I was under the car on my Brother's lift doing the oil change at 4500 miles, I noticed that one of the bolts on the differential cover had just a little moistness on it, as if it were not tightened properly.It wasn't dripping, but ws moist. I plan on having it looked at when I get some time to run it by the dealer.It was the very bottom center bolt on the diff cover (not the tranny pan).
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 04 Aug 2003, 04:55 pm
Be careful with those transmision oil leaks!!!
somebody here posted a diff lockup and the front suspension busted..
0.02
Ian
Old 04 Aug 2003, 05:33 pm
I had posted about an auto trans leak on mine. The dealer replaced a solenoid pack. They said the seal was leaking. On the work order it also says they re-sealed the trans pan. I haven't been under there yet to check up on things, but I always change my own oil so I'll have another look soon. That's how I discovered it in the first place.
Black 03 PT Turbo & Black 94 Impala SS
Old 04 Aug 2003, 08:41 pm
get it to the dealer!!
Old 10 Aug 2003, 08:25 pm
I also have noticed this on my dcII. I change the oil myself also and just happened to notice some moisture on the pan, but it seems to be coming from a connection where 2 metal tubes come down toward the pan(don't know what these are). I'm making appointment tommorrow to have it checked out.
On another note......noticed that a portion of my rear bumper paint has started to flake off where it meets the rear quarter panel. also having this checked out.
MGW LTD drops the PT rszappa1 General PT Cruiser Discussions 13 26 Oct 2005 11:26 am
drops and problems with camber Punch Wheels, Tires, Suspension 7 02 Jan 2004 04:57 pm
  Debt Consolidation | Advertising | Cheap GPS | Wordpress Theme | Find jobs
