[quote]Originally posted by mhleung
Mhle I made changes in my original post after I had a chance to trouble shoot it. Basically, I would shut the car down and follow the procedures in the owners manual. Also, after the car had cooled down I would check the PDC and make sure the Fan Control Relay is snug. I can/will send you a copy of the schematic and an image if you like. macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
I dont know how youre vehicle is set up but my car and 4 others sre all missing the 40 amp fuse in the PDC and its supposed to be missing pull it out and look where it goes there should be only one prong sticking out secondly it should be using a solid state relay/rad fan module no located in the PDC if you are having this problem refer to my OVERHEATING!!! topic in this discussion for the correction to this problem as per Chrysler Engineering.
thanks
13.88@103mph |
spidy134
RE"40A" fuse. I know, I know, I spent 4 hours looking for it and was getting really pissed, when I stopped and pulled up the circuit diagrams. After reading "all" the diagrams I finally came to the one with the Turbo circuit on it. I then went "DUHHHHHH" we need a UOC on these dam things. However there is a large connector under the PDC which I disconnected and reconnected just for the hell of it. Then I put everything back together per the spec, ensuring that I pushed on every electrical component in the PDC. Mine has been running great, but now I will be more careful before I just jump into something I will make sure that I carefully read all the techdata first. But it was fun doing it. I found out where the grounds were (grd 105 if I remember right located on the LH FWD INBD engine fenderwell) and other stuff like that. So it was time well spent. macster
bump for macster
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp |
macster
"Bump" moves the post up the list in the forum....ie this post was pages back so by me posting a reply it brought it to page 1 . The "bump" means/does nothing ,it's the posted reply that moves the post . Jeff
macster
So did you get your gage installed macster ?
macster
Good luck and let us know what you find as I have no problems doing different things !
| part numbers | Punch | General Turbo Discussions | 8 | 19 Sep 2009 08:44 pm |
| autometer water temp gauge | dfunkdj | Turbo Performance | 6 | 23 Jul 2004 05:11 pm |
| factory boost gauge | magictrickboy71 | Turbo Performance | 8 | 08 Jun 2003 12:17 am |
| Install of Water Temp Gauge | jramosGT | Turbo Performance | 6 | 18 Apr 2003 03:35 am |
| Ins5tall of Water Temp Gauge | jramosGT | Tech & Performance Forum | 1 | 01 Feb 2003 07:42 pm |
