Well I am slowly becoming a very unhappy PT Turbo owner and am contemplating selling mine. Within the past 8 months I've had the following issues, a defective slave cylinder and a seal leak in the manual transmission. Both covered under either Chrysler's Powerplant or my Max Care Chrysler Warranty and each costing $100 via the deductible. There have also been a number of other issues/failures prior to this that I won't mention.
My wife is driving home from work the other night and notes the temp gauge is pegged. After a tow (and there have been many towings of this vehicle) we learn that the water transfer tube for the turbo failed. This one, not covered by any warranty will be $350. I will be placing a call to Chrysler and attempt to get some satisfaction though I am not holding my breath. This PT GT is 5 years old, less than 50,000 miles and has been pampered. Oil changes every 3,000 miles and I've followed the service book with servicing done at certified Chrysler dealerships so as to not void any warranties. To say I am discouraged with Chrysler products at this point is an understatement. Was curious if anyone in the group has experience such an issue. W2 |
I have not heard of any problems with the water transfer tube for the turbo, either with the PT turbo or the SRT-4 (same turbo'd engine).
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
its normal wear and tear.
no car will last forever. and thats not a whole lot of $$ for service.
Nevin. 03 SRT-4 68 Mustang Coupe 05 GT Cruiser H.O. — 245hp/283tq @ 15psi 3 in intake, 2.5 in catback exhaust, Stage 1 PCM, Mopar bov, Stage 2 WGA, Check valve, 180 deg T-Stat, Ngk 4306 plugs, 10mm spark plug wires, Energy Suspention MM inserts, upper/lower hardpipes, hawk hp+ front/rear pads, Drilled/slotted rotors, steel braded front lines, Mopar 26mm Swaybar, energy suspention swaybar bushing, energy suspention swaybar endlinks, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Kobalt catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge, APC Non-turbo strut bar, 3in DP, 3in O2. waiting to go on 3in stright pipe, ported turbo, 682cc |
I use dino oil and yes the coolant level was good along with proper marks via hydrometer. I lived in Alaska for a number of years (not with this current vehicle) and know the importance of proper coolant/antifreeze. I've spent a heck of a lot more than $550 on repairs with this vehicle over the past five years ($100 deductible with each visit). Let's just say we've gotten our moneys worth out of the extended warranty. And I haven't included all the scheduled maintenance costs which are expected. I am a firm believer in regular maintenance as monies spent now will help a vehicle last longer and hopefully hold off any major mechanical failures as the years pass by. Unfortunatley this PT seems to have required more towing or unscheduled visits to the dealership compared with other vehicles I own and have owned. I still wonder if anyone else has had this piece fail on their PT GT. Again, happy my extended warranty covered it. W2 |
Synthetic Oils do better in cold weather.
The first synthetic oils were developed in the 1930s and '40s, and used in industrial applications and during wartime. In World War II, the Germans began using synthetic oil, noticing that refined crude had a tendency to freeze as they attempted to advance into Russia. Years later when jet aircraft emerged, it became clear that only synthetic oil could survive the high temperatures found within jet engines. Synthetic oils designed for cars began to appear in the 1970s. Organica News -- News and Features: When is Synthetic Better?
Yeah, I know I should be using synthetic. My Porsche and 3 motorcycles run synthetic (Mobil 1 and Amsoil motorcycle synthetic) but for some reason I've been using dino for my Toyota and PT. My bad.
![]() W2 |
They replaced the coolant tube to my '03 turbo some time ago under warranty. There was an upgraded part for it. It is a bear of a job. They had to drop the engine cradle to get to it.
| Check & drain you water heaters, A/C , &.... | Espresso | Non-PT Discussions | 17 | 12 Jul 2005 11:47 am |
| water | Jimbo | Non-PT Discussions | 3 | 12 Aug 2004 07:30 am |
