2004 GT started lurching while driving, engine light came on
Old 22 Aug 2008, 02:57 pm
Exclamation 2004 GT started lurching while driving, engine light came on
Ok I haven't checked for a code yet as I just got them. Here's the lowdown: 2 days ago my wife was driving home and car started lurching and engine light came on steady, checked the owners manual and it said emmissions related. Replaced a dirty air cleaner and breather sponge. Light went out drove fine. It happened again today. Anyone have a similar issue?(can't check code till she gets home later, just trying to get a head of it.)
Thanks
Old 03 Sep 2008, 03:53 pm
Default Re: 2004 GT started lurching while driving, engine light came on
My guess is that it is a P0340 or P0344 code. This is a crankshaft or camshaft sensor error. It has been happening a lot to me lately. When the error comes up, the engine stops doing any timing adjustment and you get misfires. I found if you are very gentle on the gas, the car will run albeit with less power.
I have replaced both those sensors and the MAP sensor and still have problems. I learned yesterday that there is a TSB about false error codes that requires an update to the engine computer. I took my car to the dealer this morning and I have the latest software but I still have the problem. The dealer was puzzled. I drive with my OBD scanner in the car and reset the computer when it comes up.
\'03 GT - No mods
\'05 Convertible Touring Ed. - No mods
Old 03 Sep 2008, 04:22 pm
can't get car above 3,000 rpms ??
Old 04 Oct 2010, 11:00 am
I have a 03 PT GT same code has anyone found the fix?
Old 04 Oct 2010, 04:41 pm
nevinsrt's Avatar
P0340-camshaft Position Sensor Circuit
P0344-camshaft Position Sensor Intermittent
is the camshaft sensor so start with replacing that.
cost $50 and easy as 2 screws to replace and its located next to your battery below your upper cold pipe.
Mopar OEM Cam Position Sensor 95-05 Neon 2.0L & 2.4L DOHC - Sensors
P0335-crankshaft Position Sensor Circuit
P0339-crankshaft Position Sensor Intermittent
then its the crank sensor which is $25
Mopar OEM Crank Position Sensor 03-05 Neon SRT4 - Sensors
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 05 Oct 2010, 01:33 pm
The code I get is P0344-camshaft Position Sensor Intermittent. The camshaft sensor has been replaced did not help. Can it be a bad cam magnet the dealer sells them $20.00 .
Old 05 Oct 2010, 02:01 pm
nevinsrt's Avatar
it could be.
Nevin.
Old 06 Oct 2010, 01:58 pm
New cam magnet is in and no code so far so good.
Old 06 Oct 2010, 06:20 pm
cruserdad1976's Avatar
where is the cam magnet??? I had this replaced the sensor it worked for 2 days and then did it again I got the sensor warranty out and then my fan quit
Old 07 Oct 2010, 11:47 am
Remove the camshaft Position Sensor then you will see the cam magnut it is fastened to the end of the cam shaft. One torques head screw is through the centre of the magnut. My dealers parts guy had never sold or seen one before.
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
