MAP sensor & code 108
Old 13 Sep 2008, 05:51 pm
Default MAP sensor & code 108
having heavy engine studder in 4th & 5th at wot...replaced plugs gapped to .040 and just put in crane fire wires...still studders. I read that you can check for a faulty map sensor by disconnecting the map sensor from manifold and trying to start car...if it starts...sensor is bad. I did this and car started...but my scangauge reported an error code of 108 (map sensor high voltage).
Does this mean the map sensor is bad?
thanks
the dreaded p0551 code - stumper djfox1 Turbo Performance 9 27 Jun 2011 03:31 pm
Mopar radio security code. Ian-PT-GT Sound and Security Forum 11 24 Feb 2010 02:19 pm
Error code trouble P0132, 1686, 1687, 1681 SolidusGorto General PT Cruiser Discussions 0 19 Jun 2008 07:59 am
Dark Plum paint code ChaosTheory The Detail Shop 3 18 Mar 2008 11:03 pm
Engine Won't Start -- Code P0129 nimblemotors Tech & Performance Forum 1 05 Jan 2008 02:10 am
