Replaced battery - Speedometer needle is off the peg
Old 07 Oct 2008, 05:20 pm
Default Replaced battery - Speedometer needle is off the peg
Does anybody know how to get the speedometer needle back on the right side of the peg? Chrysler tech used handheld computer to recalibrate and couldn't fix it. He said we need to take to cluster out and shake the needles. There has to be a better way....right? (2003 GT) Thanks.
Old 07 Oct 2008, 05:51 pm
Default Re: Replaced battery - Speedometer needle is off the peg
Maybe not, but try this.
There's a way of testing all the dials and numbers in all three parts of the guages.
Take the key and put in in the ignition but don't turn it yet. Awkward but reach over with the other hand and push in the odometer reset button, hold it in and turn the key to the ON position without starting the engine. In a second or two the numbers in the center dial will start to count up ....1111111, 2222222 etc. Now you can let go of the button but keep the key turned ON. After the numbers count all the way up, each of the dials (one at a time) will go from low to med to high, or OFF to ON, testing each dial all thru all of the guages. See what it does when the speedometer dial starts to test itself, just maybe it will reset to where it's supposed to be. Good Luck.
Old 07 Oct 2008, 06:44 pm
Thumbs up Re: Replaced battery - Speedometer needle is off the peg
AWESOME!!!
It worked! Thank you so much!
Old 07 Oct 2008, 07:01 pm
Your welcome. Glad to be of assistance. Don't forget to tell the Chrysler tech next time you see him.
problem with the PCM after battery replacement MrDove Tech & Performance Forum 20 04 Jun 2015 03:56 pm
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
New Turbo Owner Battery Questions freakengine General Turbo Discussions 4 01 Jun 2008 09:21 pm
Possible Battery Problem ? Johns Steel Blue Tech & Performance Forum 2 02 Jul 2007 08:31 am
