Question on 07 Vert Turbo
Old 11 Oct 2008, 12:01 pm
Default Question on 07 Vert Turbo
I was just at a car show and met a lady with an 07 Turbo Vert. It's a Touring Edition and has 2.4 L Trubo on the right side of the hatch.
She said she had the High Output Turbo and the saleman told her to use Premium gas.
I had my droughts and looked inside the gas door and on the inside dial where the fuel guage is. Nowhere did it say "Use Premium Fuel Only"
Her window sticker and owners manual was at home and I told her to check to see if it said High Output anywhere on the paperwork.
You owners that bought the PT with the HO engine, does it say anywhere to use Premium fuel only?
The GT version says "GT" and comes with the HO engine but is there one that has 2.4L Turbo with "High Output" on a tag under that? Can you buy the HO engine without it being a GT?
I think the lady is using Premium fuel and wasting her money.
Thanks.
Old 11 Oct 2008, 01:12 pm
Default Re: Question on 07 Vert Turbo
Does she have the normal auto tranny (turbo lite) or the autostick (HO GT)? A five speed is definitely a GT.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 11 Oct 2008, 01:20 pm
Forgot to ask or look as I didn't know that made a difference in weather it was an HO or not. Definitely not a 5 speed.
Old 23 Oct 2008, 10:35 am
teahead's Avatar
Turbo-lite. Can use mid-grade gas.
It's NOT a GT so it's NOT the high-output 2.4L turbo.
Stage 1 can take care of that.
However, to be honest, I would never buy a PT w/an auto trans.
These cars are HEAVY and even w/a turbo, it needs every help it can get. Plus, you can beef up the horsepower w/o having to worry about blowing up your trans.
2006 GT Convertible 5-speed Black
Eibach springs/ST sway bars
19x8.5 ADR wheels
235/35, 245/35 General UHPs
20% tint/XenonEyes HIDs
PTeazer Roll Pan
Borla dual 2.5" cat back
Old 23 Oct 2008, 11:48 am
In the owners manual is states that Premium Fuel is Recommended not required. It also states that the care will perform better on Premium Fuel
Old 23 Oct 2008, 01:57 pm
The 180 hp turbo lite uses regular fuel. The GT should always use premium. If one is too cheap to use premium in a GT then they should have purchased a turbo lite because that is what a GT will drop down to in power and all of that extra money that was spent on the GT is wasted.
Old 23 Oct 2008, 10:59 pm
soonercruiser's Avatar
Cool Re: Question on 07 Vert Turbo
Crewzin,
My 2006 GT Vert, The Black Sheep, a HO autostick, has "Premium Fuel Recommended" on the inside of the swing arm that holds the fuel cap. If it says it there, I don't need to read the manual!
Frank, aka SOONERCRUISER,
Old 24 Oct 2008, 11:23 am
I recommend but do not required you to read the Owners manual.
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Question about my Turbo. JMan General Turbo Discussions 4 18 Mar 2008 07:35 am
Turbo Brake System Question R_I_PT Turbo Wheels/Suspension/Handling 5 03 Nov 2007 07:44 am
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
Hahn Turbo Install Question PuterTater Cruiser Tech & Performance Forum 1 02 Oct 2002 09:26 pm
