when to have turbo checked
Old 17 Jan 2009, 11:09 pm
Default when to have turbo checked
At what mileage is it advisable to have turbo checked on 2003 PT Cruiser?
Old 18 Jan 2009, 08:26 am
Default Re: when to have turbo checked
Welcome to the forum. I've moved your post into the Turbo part of the forum for a better response. Personally, I don't think there's anything to check but we'll let the Turbo guys have a say.
Old 18 Jan 2009, 03:26 pm
I know people with well over 100k on them. They do wear out, but there isn't any particular mileage to check. You'll know by noise or if it is leaking oilo or coolant.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 18 Jan 2009, 04:37 pm
Thanks for the info.
Old 21 Jan 2009, 02:06 pm
nevinsrt's Avatar
I have almost 100k on my stock turbo SRT and have very min shaft play they will last you a long time. my wifes cruiser had pretty much none 32k
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 24 Jan 2009, 08:46 pm
Just make sure you use synth oil and you could literally go a couple hundred K miles on one with no problem
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Putting an srt-4 turbo or PT turbo, onto a N/A PT Carchrism5 Tech & Performance Forum 2 14 Dec 2005 12:27 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
