timing belt BRAND???
Old 16 Feb 2009, 08:51 am
Send a message via AIM to mtnbktrek
Question timing belt BRAND???
i just called auto shop for a new timing belt they wanted to know what brand i wanted they all were fairly close in price and had lifetime replacement i was hoping someone reads this with like 100k on a replaced belt and they know what brand it was
Old 16 Feb 2009, 11:06 am
crusierdad76's Avatar
Default Re: timing belt BRAND???
Id think that as long as you get a good lifetime warranty the brand would really matter--also depending on where you live and what auto store you use would make a difference I know Gates is a pretty big name brand where i live
Old 18 Feb 2009, 12:13 pm
nevinsrt's Avatar
Gates, goodyear gatorback there pretty good.
i use a duralast belt from autozone because its was the only belt in town and i wasnt going to the dealer back in 05 when i changed my on my SRT. now they keep alot of belts instock everywhere. and im getting ready to do it again in 10k
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 08 Mar 2009, 09:45 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
FYI duralast is a reboxed dayco belt.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Timing Belt Replacement MarkB Tech & Performance Forum 108 08 Aug 2017 12:59 am
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
loose timing belt and gears not moving - urgently need help pls. lanies_ptcruiser02 Tech & Performance Forum 12 12 Aug 2008 05:36 am
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
